Author Topic: Variables  (Read 1245 times)
Offline dannytemmermanTopic starter
Variables
« on: February 22, 2009, 10:06:39 AM »
I am wondering how the value of a sensor is known. Does the IC check the voltage and than say a value to this voltage or what? I don't understand how this goes. Would somebody please explain it to me?
Re: Variables
« Reply #1 on: February 22, 2009, 10:42:01 AM »
The 5v supply of the microcontroller is connected to the VREF pin. (Voltage reference). So if your sensor reading is outputting 2.5 volts, the microcontroller will divide 5 by 2.5 to get one-half, and then multiply it by 255 (for 8 bit ADC). I doubt the microcontroller actually goes through multiplying and dividing (there should be a more accurate way), but thats basically how it's done.
Offline ArcMan
  • Mmmm... Plasma
Re: Variables
« Reply #2 on: February 22, 2009, 01:09:09 PM »
I'm assuming you're talking about the value of an analog sensor.  Many microcontrollers come equipped with what's called an analog-to-digital converter (A/D converter).  This converter translates an analog voltage to a digital value used by your microcontroller code.  For example, a 10-bit A/D converter could convert a 0V - 5V analog input signal into a digital value with a range of 0 - 1023.
