Author Topic: Robot to climb walls?  (Read 2292 times)
Offline jianleTopic starter
« on: March 11, 2007, 09:47:15 AM »
Hi I need help for a uni project. I need to make a robot/vehicle that moves straight for 4.8metres and climbs up 2 6.5cm high and 4.2cm thick walls.
I have little knowledge on these stuff so please give some suggestions. Thanks
Offline ed1380
Re: Robot to climb walls?
« Reply #1 on: March 11, 2007, 11:07:29 AM »
« Reply #2 on: March 12, 2007, 05:14:15 AM »
yea.. but mine can't be RC-ed and actually it has to carry and deposit stuff too but the only trouble I'm facing with is the going straight and up the walls part. *sighs*
Offline JonHylands
« Reply #3 on: March 12, 2007, 06:17:15 AM »
Well, that robot that Admin built probably could be autonomous with the right on-board electronics.
Going in a straight line was discussed in a thread here a couple weeks ago. The only real issue with climbing the walls with a design like that is having the robot align itself with the wall. Seems to me a couple good analog distance sensors (like the Sharp GP2D12) mounted on each side of the robot, facing forwards, would help in aligning the robot with a wall.
- Jon
« Reply #4 on: March 16, 2007, 04:41:53 PM »
To an extent I found the robot almost self aligning itself to the wall - it wouldnt climb until both front wheels contacted the wall. So with the sharp IR that JonHylands mentioned that shouldnt be too hard.
I actually found the hardest part going back down the wall. If I wasnt careful driving it, the robot would flip over when it went over the other side. The first prototype often flipped because of a poor design and my not-yet-practiced driving skills.
I guess the point of this is, try to design it so it has passive mechanical stability (wide base with weight kept low to the ground).
Last post February 02, 2009, 08:07:47 AM
by Tomas
Last post September 05, 2009, 08:09:08 AM
Last post October 02, 2009, 04:31:46 AM
by hemanth
Last post March 20, 2010, 11:05:29 AM
by Hawaii00000
