Author Topic: Mounting Xbee and Adapter on robot??  (Read 2208 times)
« on: February 24, 2009, 01:14:45 AM »
Anyone have any good ideas on how to professionally mount a PCB without mounting holes? I am talking about the Xbee and adapter here!!
Re: Mounting Xbee and Adapter on robot??
« Reply #1 on: February 24, 2009, 03:09:27 AM »
Too bad you didn't get something like this
If you want to keep the layout with connection leads, either make a frame with notches to mount it in, or take a thin layer of foam (~1cm or so) and lay between the adapter and your main board - hold it down with an elastic band or two. Just don't thermally isolate any heat producing components.
« Reply #2 on: February 24, 2009, 11:56:46 AM »
Hey my adapter does have the holes for headers in the bottom. Thanks for getting me thinking on that.
Offline superchiku
  • cooll
« Reply #3 on: February 24, 2009, 11:58:15 AM »
looks gud what are u making?
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Offline galannthegreat
« Reply #4 on: February 24, 2009, 12:05:17 PM »
If they have any of those bigger battery boxes where you got yours try that.
Kurt
Offline ArcMan
  • Mmmm... Plasma
« Reply #5 on: February 24, 2009, 06:24:37 PM »
If I ever end up with any boards hanging out there like that, I use the 2-sided foam tape.  It's about 3/16" thick foam with adhesive on both sides.  You just peel off the backing and stick it to the board and the mounting surface.  You can get it at any home improvement store.
« Reply #6 on: February 24, 2009, 10:24:03 PM »
Thanks ArcMan, I have that stuff, but I wasn't thinking that was a very professional method. Although sticking my battery in a plastic container with the MCU mounted on top isnt very professional either.
« Reply #7 on: February 25, 2009, 11:08:41 AM »
Try the loonie store and look around for some good plastic containers, and then paint it with some acrylic paint and add your own professional design/look to it.
Kurt
« Reply #8 on: February 25, 2009, 11:13:21 AM »
hah whats  a loonie store?
« Reply #9 on: February 25, 2009, 11:15:30 AM »
... you can't tell me that you never went into a dollar store?
Kurt
« Reply #10 on: February 25, 2009, 12:11:27 PM »
yeah i have just never heard it called a loonie store before!
Offline chelmi
« Reply #11 on: February 25, 2009, 12:39:17 PM »
I think it's a Canadianism
« Reply #12 on: February 25, 2009, 02:35:33 PM »
Well put, I'm a Canuck, so I guess I would put it that way. Sorry 'bout that I guess my Canuck ways took over me, so how does that idea sound, eh? (the dollar store one)
Kurt
« Reply #13 on: March 01, 2009, 09:43:58 AM »
Velcro is better than the double sided sticky tape. The tape is semi-permanent, while the velcro will allow you to move your Xbee to the next robot (in the future, when you decide this robot is an embarrassment and must be destroyed).
