Author Topic: Soldering Wires Onto The PC Board  (Read 2176 times)
Offline Joesavage1Topic starter
« on: February 26, 2009, 11:19:23 AM »
In the $50 tutorial, you have to solder wires to the pads, i find this REALLY HARD!, i spent 1 hour doing 1 wire. Can someone give me some tips.
Joe
Offline chelmi
Re: Soldering Wires Onto The PC Board
« Reply #1 on: February 26, 2009, 11:31:25 AM »
Joe
If you are using stranded wire, you need to tin your wire first. Heat the tip of the wire with you iron and apply a small quantity of solder. Your wire will "absorb" the solder. Then solder it to the pad as usual. Hope this helps !
Chelmi.
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
« Reply #2 on: February 26, 2009, 06:48:00 PM »
There is a kind of wire that strips itself as you apply heat with the soldering gun on it with some gentle move....
It has helped me a hell to do prototyping...
I'll try to find the name and post it tomorrow....
But... it is really a matter of skill eeehhh.... It will take you some time to learn how the solder behaves....
and how to act properly....
Remember that even gravity matters when soldering...
So I'll get you the name of the wire... so you can supply yourself some... but it's a little bit of expensive so be ready...
Cheers!
Offline pomprocker
« Reply #3 on: February 26, 2009, 06:54:05 PM »
tin the tip of your soldering iron as well, this helps transfer heat and makes things solder a lot quicker.
« Reply #4 on: February 27, 2009, 01:15:38 AM »
Im using Copper Insulated Wire, 22 gauge (i think), just to say. And also just to say: i think it would be so much easier if you had 4 hands!
Joe
Offline cosminprund
  • Helpful? 8
« Reply #5 on: February 27, 2009, 01:33:03 AM »
Get yourself some thinner, multi-strand wire. 22 gauge is thick and that would make it more difficult to use. Multi-strand wire is very solder friendly and it doesn't break so easily when you move it around. Because it's more flexible it will be less likely to brake out of the solder bead.
I also use a pair of tweezers to hold the wire down to where I want it soldered: my hand moves enough to make the job difficult + my hand doesn't like the heat of the soldering iron :)
If you don't have tweezers then do whatever you can to make the wire stay in place by itself.
And of course, as TrickyNekro puts it:
you need to practice...
« Reply #6 on: February 27, 2009, 02:04:45 AM »
if you think you need four hands  maybe you should pick up a pair of helping hands, i just made my own :)
Offline superchiku
  • cooll
« Reply #7 on: February 27, 2009, 02:48:11 AM »
u ned to use some kind of solder paste(i dont know the exact name)...this helps the solder to fix to the wire ...1st heat up the solder iron and apply some paste to the tip then apply some solder to it and try to solder ur components...:D
JAYDEEP ...
IT AND ROBOTICS ENGINEER
« Reply #8 on: February 27, 2009, 04:47:15 AM »
aslong as you use a thin enough wire even the biggest noob will get get it right 3rd or 4th go.
« Reply #9 on: February 27, 2009, 09:24:49 AM »
My wire is STUPIDLY THIN, so maybe its not 22 guage, its also extremely flexible.
I wil however be trying some of the other tips.
Joe
Offline fuzzyt
« Reply #10 on: February 27, 2009, 10:01:55 AM »
If you tin the pad and the wire, then apply a small amount of solder paste ( flux ) to the pad, then you should be able to just hold the wire to the pad and apply heat.  Although not a "proper" technique, you can heavily tin your iron and some of the solder from the iron will flow toward the flux on the joint as well.  This can really help in those "not enough hands" situations.
« Reply #11 on: February 28, 2009, 01:20:37 AM »
Ok Thanks, ill post if i encounter more problems
(liike bridging, while i was waiting for you to reply i gave it a try, lol, did one side of pins but took me ages,  :D.
Joe
« Reply #12 on: March 03, 2009, 05:55:46 AM »
When I made that tutorial, I forgot that beginners would have trouble soldering . . . I recommend using an empty part of your board and practice practice practice. When you got it figured out, then start soldering the rest.
« Reply #13 on: March 03, 2009, 09:25:36 AM »
Im ok at soldering the parts in, but the wires i just find really hard. So im leavign them till the end after the bridging and stuff (ive done half the bridging or wtv, its quite hard.)
Joe
Offline dellagd
« Reply #14 on: March 04, 2009, 03:09:15 PM »
what I did was I got 2 PCBs and just praticed on that.
Also make sure your tip is clean!
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
Last post September 20, 2008, 08:47:55 AM
by MaltiK
Last post November 01, 2008, 04:15:11 PM
by Stragen
Last post May 09, 2010, 05:43:39 PM
by Chuckt
Last post February 26, 2012, 10:54:55 AM
by ivern
