Author Topic: Electrical door release?  (Read 1104 times)
Offline MaltiKTopic starter
« on: March 01, 2009, 02:45:30 PM »
I am building a radio controlled open/close electrical opener/closer (lock when close) and I have been trying to think of the mechanical scheme for this. Should I use a solenoid or an electromagnet? When it is high the magnet will attract, and when low the magnet will repel.
And a solenoid would just have one way (open)
So is there a product similar to the magnet I mentioned, and cheap?
Edit: this is a light door, a minifridge, but requires a strong magnet or solenoid to lock and stay locked similar to a deadbolt, aside from the fact that deadbolts dont open the door, just unlock them.
« Last Edit: March 01, 2009, 02:48:38 PM by MaltiK »
Warranty
Re: Electrical door release?
« Reply #1 on: March 01, 2009, 02:55:44 PM »
well you could consider suction if the fridge has a seal on it. or if you only want it to unlock or lock and not fly open you could use solenoids. electromagnets are a maybe but they might cause interference with other appliances and or the contents of the fridge.
Offline ed1380
« Reply #2 on: March 01, 2009, 03:27:48 PM »
whats the budget? size restraints?
id use a linear actuator and pu it like the pic
« Reply #3 on: March 01, 2009, 04:50:31 PM »
That picture is real confusing, could you explain it?
Warranty
« Reply #4 on: March 01, 2009, 04:54:20 PM »
Black dot is the hinge of the door - if the linear actuator(on the left side) gets shorter, the door opens.
Last post January 08, 2007, 08:20:49 AM
Last post April 24, 2007, 06:16:14 PM
Last post September 16, 2010, 07:31:36 AM
by waltr
Last post March 16, 2012, 09:38:40 PM
