Author Topic: Arduino Code for Stampy algorithm  (Read 3150 times)
Offline jkflorekTopic starter
« on: March 02, 2009, 06:12:54 PM »
I decided to try and port the Stampy algorithm to Arduino code, could you guys check it out and see if I made any errors?
Thanks,
   jkflorek
*    Copyright (c) 2009 Jeff Florek <[email protected]                      *
*    Based off of code found at http://www.societyofrobots.com/              *
*    This program is free software; you can redistribute it and/or modify    *
*    it under the terms of the GNU General Public License version 2 as       *
*    published by the Free Software Foundation.                              *
*    Alternatively, this software may be distributed under the terms of BSD  *
*    license.        *
*    $50 Robot with Arduino MCU and Sharp IR using Stampy Technology,        *
*    May 2nd, 2009                                                           *
*    Simple case-based method for a robot to do edge detection.              *
#include <Servo.h>
Servo right_wheel;
Servo left_wheel;
Servo scanner;
int distance = 0;  //holds value from IR scanner
int scan_threshold = 0;  //threshold for detecting an object
int scan_angle = 90;  //angle that the scanning servo is at
int led_pin = 13;  //pin that status LED is connnected to
int scanner_pin = 0;
//scans for target
void scan()
  distance = analogRead(scanner_pin);
  if(distance > scan_threshold)  //object detected
    if(scan_angle > 0)  //overflow protection
      scan_angle -= 1;  //turn scanner left
  else  //no object detected
    if(scan_angle < 180)  //overflow protection
      scan_angle += 1;  //turn right
  scanner.write(scan_angle);  //set servo angle to scan_angle
void auto_calibrate()  //automatically find the target sensing threshold
  scan_threshold = analogRead(scanner_pin);
void setup()
  right_wheel.attach(3);
  left_wheel.attach(5);
  scanner.attach(6);
  pinMode(led_pin, OUTPUT);
  //Turn LED on to signal autocalibration,
  //wait 2 seconds, autocalibrate, then turn LED off
  digitalWrite(led_pin, HIGH);
  delay(2000);
  auto_calibrate();
  digitalWrite(led_pin, LOW);
void loop()
  scan();
  //if object detected on left, turn left
  if(scan_angle <= 50)
    right_wheel.write(135);
    left_wheel.write(135);
  //if object detected on right, turn right
  else if(scan_angle >= 130)
    right_wheel.write(45);
    left_wheel.write(45);
  //object is centered, go strait
  else
  delay(15);  //small delay to prevent crazy oscillations
Re: Arduino Code for Stampy algorithm
« Reply #1 on: March 04, 2009, 06:31:33 PM »
no comments? :(
« Reply #2 on: March 19, 2009, 03:25:30 AM »
I think you should test it on a robot to see if it works before asking if it works or not :P
Plus, its already been ported to the ATmega8! ;D
http://www.societyofrobots.com/robot_50_robot_sharpIR.shtml
