Author Topic: ooPic R and L297/L298 for Stepper  (Read 2368 times)
Offline vivek9856Topic starter
« on: March 03, 2009, 08:37:26 PM »
I am using an ooPic R to control a L297 which drives an L298 which drives a stepper motor. I'm trying to figure out how to get the correct clock signal out of the ooPic.
First off, I would need to use the oFreq object to generate a clock signal for the L297, correct? Or does the L297 use PWM on the clock line?
Secondly, I would need to use the oFreqH object on the Pic to get a high enough frequency to drive the L297. However, a speaker is connected to Line 21 on the R board. How can I remove the speaker and connect an I/O pin? I tried removing the solder on the back of the speaker and pulling, but it didn't move. Is it glued down?
Re: ooPic R and L297/L298 for Stepper
« Reply #1 on: March 24, 2009, 11:54:29 PM »
This sounds incredibly overcomplicated . . . is there a reason you didn't buy a $15 stepper motor driver?
http://www.sparkfun.com/commerce/product_info.php?products_id=8368
 :P
Last post April 25, 2008, 01:18:19 PM
Last post September 16, 2008, 09:02:14 AM
by ArcMan
Last post March 25, 2011, 03:15:43 AM
Last post August 03, 2011, 08:24:46 PM
