Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
November 20, 2009, 09:06:17 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Search:
Advanced search
Sept 30th - The
5th SoR Robot contest
is now open! Win an Axon II!
Robot Forum
72,665
Posts in
9,267
Topics by
5,290
Members
Latest Member:
robertelson
Robot Forum
Software
Software
HOW TO: SPI on Axon
Pages:
1
Author
Topic: HOW TO: SPI on Axon (Read 692 times)
sprince09
Jr. Member
Helpful? 0
Offline
HOW TO: SPI on Axon
on:
March 04, 2009, 07:41:10 PM »
Hey guys,
I've been trying to get my Axon to interface with an SDCard (I need to do some data-logging) over the SPI interface. I read through the spi.c and spi.h files included in the latest source code for the Axon and I have been trying to use those functions to interface with my card. Going off of the pin labels in the Axon datasheet and a google search for the pinout of an SDCard, I'm fairly certain that I have my connections set up properly. Anyway, what I've noticed is that whenever I plug in my SDCard, the board resets continually until I remove, which indicates to me that I have a wiring problem somewhere, but I've rebuilt the circuit four times now, and I haven't been able to find any errors with that.
I guess what I'm really interested in knowing is if there are any special considerations I need to make when using SPI on the axon. I noticed that the hardware programmer uses the same pins (except for SS and reset) as SPI does... is there something I should be doing to account for that?
Relevant code that I am running:
void SPITest(void){
rprintfInit(uart1SendByte);
rprintf("\n\r");
spiInit();
rprintf("SPI Interface Successfully Initialized\r\n");
unsigned char a = 0;
while(1){
spiSendByte(a++);//this function blocks until register is cleared (won't clear if nothing is connected?)
rprintf("byte sent: %c \r",a);
Also, when I run the code without the SDCard attached, I get the initialization response over my UART "SPI Interface etc..." and then it blocks at spiSendByte(a++). My understanding of that function is that it will block until the data has been shifted out of the register (can't remember what register off the top of my head). I expected that it will block if the pin is unconnected (maybe I'm wrong).
Anyway, I'd appreciate any insight into this
EDIT: Read my next post!
Last Edit: March 13, 2009, 11:53:40 AM by sprince09
Logged
sprince09
Jr. Member
Helpful? 0
Offline
Re: SPI woes (Axon)
Reply #1 on:
March 13, 2009, 11:47:35 AM »
Alright, after much frustration and self doubt I've figured out what was wrong. I ended up writing my own initialization function:
spi_init(void){
unsigned char a;
//setup pins
#define MISO PB3
#define MOSI PB2
#define SCK PB1
#define SS PB0
DDRB |= (1<<MOSI)|(1<<SCK)|(1<<SS);
DDRB &= ~(1<<MISO);
PORTB |= (1<<SS);//set SS high
PORTB &= ~(1<<MISO);//turn off internal pullup for MISO
PORTB &= ~(1<<MOSI);//pull MOSI low
PORTB &= ~(1<<SCK);//pull SCK low
//setup registers
SPSR = 0b00000000;//see datasheet
SPCR = 0b01010000;//see datasheet
//clear out any junk in SPI buffer
a = SPSR;
And the corresponding function for sending+receiving data:
unsigned char spi_transfer(unsigned char data){
//transmits data over SPI lines and returns the response
SPDR = data;
while(!(SPSR & (1<<SPIF)));//block untill data transmission/reception completes
return SPDR;
It turns out that setting up the software side of the interface wasn't my problem... it was the hardware. The axon_schematic.pdf labels the ISP programming headers (the SPI pins are also the programmer pins) as follows:
Left Right
VTG MISO
RST MOSI
GND SCK
However, the actual layout of the programming pins is:
Left Right
MISO VTG
SCK MOSI
RST GND
Works perfect for me now. Hope this helps anyone else who is having issues.
Logged
pomprocker
Supreme Robot
Helpful? 15
Offline
Sorry miss, I was giving myself an oil-job.
Re: SPI woes (Axon)
Reply #2 on:
March 13, 2009, 11:52:10 AM »
Can you relabel this thread so that anyone searching for this problem in the future has an easier time finding it due to a more descriptive thread subject
Logged
Blog:
Nerd Stuff - Programming, Electronics, Mechanics
sprince09
Jr. Member
Helpful? 0
Offline
Re: HOW TO: SPI on Axon
Reply #3 on:
March 13, 2009, 11:53:54 AM »
Updated
Logged
Pages:
1
Jump to:
Please select a destination:
General Misc
=> Misc
=> Robot Videos
Software
=> Software
Electronics
=> Electronics
Mechanics and Construction
=> Mechanics and Construction
Subject
Started by
Replies
Views
Last post
Axon
Electronics
gamefreak
5
1721
July 18, 2008, 09:28:26 PM
by
Admin
AXON
Electronics
jronald
20
3634
February 10, 2009, 04:35:35 PM
by
frodo
axon adc
Software
vidam
1
836
August 31, 2008, 06:58:11 PM
by
Admin
PWM on Axon
Software
mbateman
10
2923
March 23, 2009, 04:07:14 PM
by
Hanoush
Advertise on this Forum
Loading...
