Author Topic: HOW TO: SPI on Axon  (Read 2811 times)
Offline sprince09Topic starter
HOW TO: SPI on Axon
« on: March 04, 2009, 09:41:10 PM »
Hey guys,
I've been trying to get my Axon to interface with an SDCard (I need to do some data-logging) over the SPI interface. I read through the spi.c and spi.h files included in the latest source code for the Axon and I have been trying to use those functions to interface with my card. Going off of the pin labels in the Axon datasheet and a google search for the pinout of an SDCard, I'm fairly certain that I have my connections set up properly. Anyway, what I've noticed is that whenever I plug in my SDCard, the board resets continually until I remove, which indicates to me that I have a wiring problem somewhere, but I've rebuilt the circuit four times now, and I haven't been able to find any errors with that.
I guess what I'm really interested in knowing is if there are any special considerations I need to make when using SPI on the axon. I noticed that the hardware programmer uses the same pins (except for SS and reset) as SPI does... is there something I should be doing to account for that?
Relevant code that I am running:
void SPITest(void){
  rprintfInit(uart1SendByte);
  rprintf("\n\r");
  spiInit();
  rprintf("SPI Interface Successfully Initialized\r\n");
  unsigned char a = 0;
  while(1){
    spiSendByte(a++);//this function blocks until register is cleared (won't clear if nothing is connected?)
    rprintf("byte sent: %c       \r",a);
Also, when I run the code without the SDCard attached, I get the initialization response over my UART "SPI Interface etc..." and then it blocks at spiSendByte(a++). My understanding of that function is that it will block until the data has been shifted out of the register (can't remember what register off the top of my head). I expected that it will block if the pin is unconnected (maybe I'm wrong).
Anyway, I'd appreciate any insight into this  :-\
EDIT: Read my next post!
« Last Edit: March 13, 2009, 12:53:40 PM by sprince09 »
Re: SPI woes (Axon)
« Reply #1 on: March 13, 2009, 12:47:35 PM »
Alright, after much frustration and self doubt I've figured out what was wrong. I ended up writing my own initialization function:
spi_init(void){
  unsigned char a;
  //setup pins
  #define      MISO         PB3
  #define      MOSI         PB2
  #define      SCK         PB1
  #define      SS         PB0
  DDRB |= (1<<MOSI)|(1<<SCK)|(1<<SS);
  DDRB &= ~(1<<MISO);
  PORTB |= (1<<SS);//set SS high
  PORTB &= ~(1<<MISO);//turn off internal pullup for MISO
  PORTB &= ~(1<<MOSI);//pull MOSI low
  PORTB &= ~(1<<SCK);//pull SCK low
  //setup registers
  SPSR = 0b00000000;//see datasheet
  SPCR = 0b01010000;//see datasheet
  //clear out any junk in SPI buffer
  a = SPSR;
And the corresponding function for sending+receiving data:
unsigned char spi_transfer(unsigned char data){
//transmits data over SPI lines and returns the response
  SPDR = data;
  while(!(SPSR & (1<<SPIF)));//block untill data transmission/reception completes
  return SPDR;
It turns out that setting up the software side of the interface wasn't my problem... it was the hardware. The axon_schematic.pdf labels the ISP programming headers (the SPI pins are also the programmer pins) as follows:
 Left       Right
 VTG       MISO
 RST       MOSI
 GND      SCK
However, the actual layout of the programming pins is:
 Left      Right
 MISO    VTG
 SCK      MOSI
 RST      GND
 ;) Works perfect for me now. Hope this helps anyone else who is having issues.
Offline pomprocker
  • Helpful? 16
Re: SPI woes (Axon)
« Reply #2 on: March 13, 2009, 12:52:10 PM »
Can you relabel this thread so that anyone searching for this problem in the future has an easier time finding it due to a more descriptive thread subject
Re: HOW TO: SPI on Axon
« Reply #3 on: March 13, 2009, 12:53:54 PM »
Updated
Offline Hawl
« Reply #4 on: January 13, 2011, 10:01:09 PM »
Just wanted to say thanks for this thread. Saved me a whole lot of time figuring out the pinout on the datasheet is wrong!
Last post July 18, 2008, 10:28:26 PM
Last post November 06, 2008, 01:22:49 AM
Last post November 28, 2008, 11:09:42 PM
by Bret
Last post March 15, 2009, 12:40:30 AM
