Author Topic: Micro Servo Issue  (Read 843 times)
Offline CanabotsTopic starter
  • Helpful? 6
Micro Servo Issue
« on: March 05, 2009, 05:54:10 PM »
Hi all!
I just bought 2 micro servos from raidentech.com (the 8g ones). So I plug it into a test circuit, but all I got from the servo is a faint hum (occasionally). So I tried my Standard HS-311 servo, and the test ran perfectly.
Upon inspection to the servo, there's a label saying "Digital Servo  E-Sky  EK2-0508"
How different is the control of a digital servo from an analogue one? Will I have to get one of those special programmers? :-[
Here's the code on the PIC:
#include <pic.h>
#include "delay.h"
__CONFIG(INTIO & WDTDIS & PWRTEN & MCLRDIS & UNPROTECT
 & BORDIS & IESODIS & FCMDIS);
int j,i,k;
main()
TRISA = 0b111110;
while (1)
for(j=0;j<250;j++)
RA0 = 1;
DelayUs(250);
DelayUs(250);
DelayUs(250);
RA0 = 0;
DelayMs(18);
for(j=250;j>0;j--)
RA0 = 1;
DelayMs(1);
RA0 = 0;
DelayMs(18);
for(i=0;i<250;i++)
RA0 = 1;
DelayMs(1);
DelayUs(250);
DelayUs(250);
RA0 = 0;
DelayMs(18);
for(i=250;i>0;i--)
RA0 = 1;
DelayMs(2);
RA0 = 0;
DelayMs(18);
for(k=0;k>250;k++)
RA0 = 1;
DelayMs(2);
DelayUs(250);
DelayUs(100);
RA0 = 0;
DelayMs(18);
Thanks in advance for any help! :)
Canabots
www.saltech.wordpress.com
Re: Micro Servo Issue
« Reply #1 on: March 05, 2009, 06:23:23 PM »
Digital servos take the same signals as analog servos.
Servos from raidentech are of poor quality, you might have received a dud.
  • Helpful? 6
« Reply #2 on: March 05, 2009, 07:29:47 PM »
uhoh, that's not good :'(
Are the signal ranges maybe higher or lower than analog servos (as in, instead of say 1 ms, maybe .5ms? Or instead of 2ms maybe 2.5ms?)
I suppose that if worst comes to worst I can salvage the motor and gearbox from the servos, but I'd rather try as much as possible before doing anything like that.
Quick Edit: I found this (http://www.futaba-rc.com/servos/digitalservos.pdf) describing the control of a digital servo. Does anyone know what sort of timing the pulses require for the servo to move?
« Last Edit: March 05, 2009, 07:47:46 PM by Canabots »
Last post November 08, 2008, 05:57:15 PM
by sdavis6736
Last post September 18, 2011, 06:01:09 PM
Last post July 12, 2012, 06:43:09 PM
by Pogertt
Last post December 02, 2012, 02:53:04 PM
by Mastermime
