Author Topic: robot legs  (Read 1953 times)
Offline dellagdTopic starter
robot legs
« on: March 07, 2009, 10:29:42 AM »
Hi- I was wondering which would be the best way to move the legs of a legged robot?
linear motors?
air bladders?
nitona wire(muscle wire)?
If any of you have any ideas or experience on this subject, I would like to hear it
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
Offline sean22
Re: robot legs
« Reply #1 on: March 07, 2009, 07:58:32 PM »
I would go for the servos they are cheap and relativity easy to program, linear motors air bladders nitona wire(muscle wire) are fairly expensive and are bigger. so servo are probably you best bet
First Robotics - 2009
Canada Skills Robotics - 2009
Offline Spider
Re: robot legs
« Reply #2 on: March 08, 2009, 12:41:30 AM »
You could consider a linkage that doesn't require any of the above. There are several linkages out there that convert rotary motion to linear movement that may meet your design criteria. The klann linkage would be a starting point.
Offline offy
Re: robot legs
« Reply #3 on: March 08, 2009, 08:09:14 PM »
I say you should use servos. They are small, cheap, and most robots use servo's for legs so you can probably find a good amount of help with it.
