Author Topic: Fixing my IR  (Read 2015 times)
Offline JDeschambaultTopic starter
Fixing my IR
« on: March 14, 2007, 07:32:30 PM »
Here it goes... I am on my 2nd robot. and on this one i want to use IR. I have reseached it with this web site and several others. I bought the parts build it and plugged it in to test my ciruits and see what kind of readings i would be getting. the thing is i am only getting readings 2 inches in front of it. Further I am not sure the program i wrote is giving me the readings it should or if i need to write a different program. (the Program i wrote is set up to read a photoresister.) i used the IR sensor SCHEMATICS - INFRARED EMITTER DETECTOR. and in place of the 120 ohms, used 150 and in place of the 11k used 10k. (closest i could find at the time) any help to solve this would be great...  :o
"The only good is knowledge and the only evil is ignorance."
Socrates
Offline sdk32285
Re: Fixing my IR
« Reply #1 on: March 14, 2007, 07:50:08 PM »
Is the your IR sensor analog or digital. Is the photoresistor program designed to act on a value or is it thresholded to either be on or off? If you have a meter test the output of the IR sensor without being attached to the micro.
Re: Fixing my IR
« Reply #2 on: March 14, 2007, 08:05:53 PM »
the Program is a 5DEC value, the IR i am not sure but if i was guessing Ang. cause it is not simply on or off. (See http://www.societyofrobots.com/schematics_infraredemitdet.shtml to see the ciruit i built)   :-\
i have a Meter but not sure How to test it, and if it should have power running through it...? ???
Socrates
Offline sdk32285
Re: Fixing my IR
« Reply #3 on: March 14, 2007, 08:20:36 PM »
What type of IR sensor is it?
To test have the circuit powered and measure the voltage between Vout and GND
Re: Fixing my IR
« Reply #4 on: March 14, 2007, 08:42:05 PM »
obstacle detection, and i will test it once i get home tonight.
Socrates
Re: Fixing my IR
« Reply #5 on: March 16, 2007, 05:43:08 PM »
actually, for that sensor two inches sounds about right.
you have a few options . . . one would be to use more emitter LEDs, and/or brighter emitter LEDs. another other option would be to do signal modulation to remove background noise. and lastely, you could use op-amps to boost your signal.
if you want really good range, the best method is to use Sharp IR rangefinders
Last post March 23, 2009, 11:21:31 PM
by pomprocker
Last post May 01, 2009, 09:44:52 PM
by protoadv
Last post March 29, 2010, 11:30:03 PM
by SmAsH
Last post March 09, 2013, 01:41:59 AM
by jwatte
