Author Topic: Honestly, what am I missing?  (Read 866 times)
Offline jsmokerTopic starter
« on: March 09, 2009, 09:41:04 AM »
I've done tons of projects with the dsPIC30F3012 and now suddenly I can't get a simple LED to light up.  I have a 5V power supply source with a .33uF cap on the source.  The dsPIC is set to use it's own oscillator.  Here's the code.  Maybe it's just a brain fart.  I should be able to do this in my sleep.
#include "p30fxxxx.h"
_FOSC(CSW_FSCM_OFF & FRC_PLL8); //Internal Clock routed through the PLL8
_FWDT(WDT_OFF);                 //Turn off the Watch-Dog Timer.
_FGS(CODE_PROT_OFF);
_FBORPOR(PBOR_OFF & MCLR_DIS & PWRT_OFF); //MCLR must be disabled to reprogram while using internal oscillator
void mdelay(unsigned int dcycle);
int main(void)
_LATD0 = 0;
int j = 0;
for(j = 0; j < 10; j++)
mdelay(3000);
while(1)
_LATD0 = 1;
return 0;
int i;
for(i = 0; i < dcycle; i++)
Nop();
« Last Edit: March 09, 2009, 09:42:14 AM by jsmoker »
Offline paulstreats
  • Helpful? 20
Re: Honestly, what am I missing?
« Reply #1 on: March 09, 2009, 10:16:25 AM »
do you need TRISD setting to output?
« Reply #2 on: March 09, 2009, 10:24:34 AM »
Yep! That was it.  For some reason I thought they defaulted to 0.
 Thanks!
« Last Edit: March 09, 2009, 10:25:53 AM by jsmoker »
Last post January 24, 2009, 12:51:04 AM
by pomprocker
Last post September 23, 2009, 08:56:01 AM
by bsamuels
Last post November 15, 2009, 04:10:01 PM
Last post April 27, 2013, 02:08:46 PM
by Webbot
