Author Topic: Sorting Algo check up!  (Read 989 times)
Offline TrickyNekroTopic starter
  • Helpful? 15
  • 1.6L Peugeot 307 tuner
« on: March 09, 2009, 08:50:53 PM »
Hello guys,
 I was just sitting at my chair and trying to make a space and time efficient algorithm for
a little something I'm preparing... I was only familiar with the bubble sort but it's too slow and inefficient
so I came up to this as an idea of mixing smart bubble sort and insertion sort...
Please have a look and tell me your thoughts about it!!!
Let's say we have a 50 element array:
A[1] <- GetADC
FOR i = 1 TO 49
  temp <- GetADC
  IF temp > A[i] THEN
     A[i+1] <- temp
  ELSE
    j <- i
   WHILE a <- false
      A[j+1] <- A[j]
      j <- j - 1
     IF j = 0 THEN
       A[1] <- temp
       a <- true
     ELSE
       IF temp > A[j] THEN
         A[j+1] <- temp
         a <- true
       ENDIF
     ENDIF
   WEND
  ENDIF
NEXT
Cheers!
Offline superchiku
  • cooll
Re: Sorting Algo check up!
« Reply #1 on: March 10, 2009, 01:15:25 AM »
use merge sort or quicksort instead don use bubble sort or inserton sort the have max time complexity of n^2 while quick sort has nlogn
i have sample quick sort programs and merge sort programs in c...hope u know c...
# include<stdio.h>
# include<conio.h>
int a[10];
int divideandconquer(int low,int high)
  int i,j,reference;
  i=low-1;
  j=high+1;
  reference=a[low];
  while(i<j)
      do
      i++;
     }while(a[i]<reference);
    do
      j--;
     }while(a[j]>reference);
    if(i<j){
    a[i]=a[i]+a[j];
    a[j]=a[i]-a[j];
    a[i]=a[i]-a[j];
     else
       return(j);
void quicksort(int low,int high)
  int j;
  if(low<high)
  j=divideandconquer(low,high);
  quicksort(low,j);
  quicksort(j+1,high);
 void main()
   int g;
   clrscr();
   printf("\nenter the elements");
   for(g=0;g<=9;g++)
     printf("\n insert the %dth element",g+1);
     scanf("%d",&a[g]);
   quicksort(0,9);
   printf("\n sorted array is ");
   for(g=0;g<=9;g++)
      printf(" %d ",a[g]);
   getch();
merge sort
# include<stdio.h>
# include<conio.h>
# include<math.h>
int a[10];
void merge(int,int,int);
void mergesort(int low,int high)
   int mid;
    if(low<high)
mid=(low+high)/2;
         mergesort(low,mid);
mergesort(mid+1,high);
         merge(low,mid,high);
void merge(int low,int mid,int high)
   int *temp,i,j,k;
   i=low;
    j=mid+1;
   temp=(int*)malloc(sizeof(int)*(high-low+1));
   k=0;
   while(i<=mid && j<=high)
if(a[i]<a[j])
    temp[k]=a[i];
    i++;
    k++;
else
     temp[k]=a[j];
     j++;
     k++;
  while(i<=mid)
      temp[k]=a[i];
      i++;
      k++;
   while(j<=high)
       temp[k]=a[j];
j++;
k++;
    k=0;
    for(i=low;i<=high;i++)
a[i]=temp[k];k++;
 void main()
   int g;
   clrscr();
   printf("enter the elements\n");
   for(g=0;g<=9;g++)
     printf("\n enter the %dth element",g+1);
     scanf("%d",&a[g]);
   mergesort(0,9);
   printf("\n the sorted array is");
   for(g=0;g<=9;g++)
  getch();
JAYDEEP ...
IT AND ROBOTICS ENGINEER
  • Helpful? 15
« Reply #2 on: March 10, 2009, 05:14:18 AM »
Thank man, but unfortunately...
It was a little bit hard for me to read...
I made a try to understand merge but it gives me the creeps...
Quick sort is understandable fortunately....
Any other recommendations are more than well come!!!
better in pseudocode...
Cheers!
Offline chelmi
  • Helpful? 15
« Reply #3 on: March 10, 2009, 07:41:09 AM »
If there in ONE algorithm you shouldn't invent in 2009, it's a sorting algorithm ;)
http://en.wikipedia.org/wiki/Merge_sort
http://en.wikipedia.org/wiki/Quicksort
Last post November 03, 2008, 06:17:11 AM
by sdavis6736
Last post January 27, 2010, 11:52:53 PM
by mohit sharma
Last post May 12, 2010, 09:23:22 AM
by corrado33
Last post January 08, 2013, 05:46:01 AM
by redloff
