Author Topic: IR Remot controle  (Read 4788 times)
Offline 555 timer chip guyTopic starter
IR Remot controle
« on: March 15, 2007, 05:01:15 PM »
I am having some trouble with making a 38 KHz transmiter I am using a 555 unstable oscillator circuit but for some reason my 38 KHz receiver is not picking up the signal but works fine with a standard TV remote. Dose any one have a suggestions.
Offline dunk
Re: IR Remot controle
« Reply #1 on: March 16, 2007, 06:07:49 AM »
many ccd cameras can see infared light.
find a camera that can see your tv remote and compair the brightness of your circuit.
Offline Kohanbash
« Reply #2 on: March 16, 2007, 08:05:00 AM »
A lot of time on higher end cameras there is an IR filter that can be removed.
Offline hgordon
  • Helpful? 7
« Reply #3 on: March 16, 2007, 09:10:46 AM »
You need an oscilloscope to view the waveform of the IR emitter circuit.  Look for a Radio Shake ProbeScope -
    http://www.linuxtoys.org/pscope/pscope.html
or do a web search on serial port / USB oscilloscopes.  If you are building your own circuits, you won't use an oscilloscope too often, but when you need it, there is no better tool for sorting out waveform problems.
Surveyor Corporation
  www.surveyor.com
« Reply #4 on: March 16, 2007, 08:12:32 PM »
I have an oscilloscope but it can only read up to 5 KHz and the only oscilloscope that I fond that can read 38 KHz is $400.
Offline hgordon
  • Helpful? 7
« Reply #5 on: March 16, 2007, 09:26:32 PM »
You can sometimes find the ProbeScope on eBay for around $70.  Also, there seems to be a US distributor for the product, which is actually called osziFOX -
    http://www.biotechproducts.com/wittig-oszifox.html
According to what I've seen, this scope can sample up to 2MHz.
I have a Velleman HPS40 scope that cost about $200.  It is not the great scope, but it has paid for itself in troubleshooting some problems, including some 38kHz IR circuits.
  www.surveyor.com
« Reply #6 on: March 18, 2007, 10:22:11 AM »
I was thinking maybe the receiver receives pulse with modulation.
Offline hgordon
  • Helpful? 7
« Reply #7 on: March 18, 2007, 12:22:02 PM »
What IR receiver are you using ?
  www.surveyor.com
« Reply #8 on: March 18, 2007, 05:31:18 PM »
A 38 KHz receiver from radio shack.
Offline hgordon
  • Helpful? 7
« Reply #9 on: March 18, 2007, 06:30:43 PM »
Well ... if the IR receiver is indicating a received signal from your TV remote, it probably is working fine.  The remote sends out a bit pattern by turning on and off a 38kHz IR transmitter, so the receiver will show a HIGH output when it is receiving the 38kHz signal, and LOW when it isn't.  The filtering on the receiver isn't that tight, so a 36kHz signal or 40kHz signal will still trigger a HIGH.  From your description, it seems that your transmitter isn't producing anywhere close to 38kHz.
  www.surveyor.com
« Reply #10 on: March 19, 2007, 02:21:22 PM »
Please explain this bit pattern is it possible to create this with a 555 ustable and a monostable oscillator circuit if not please tell me how.  :)
Offline hgordon
  • Helpful? 7
« Reply #11 on: March 19, 2007, 03:37:29 PM »
I use the processor to generate bit patterns that control the IR emitter from software, so I can't tell you how to do this with a 555.
  www.surveyor.com
« Reply #12 on: March 20, 2007, 05:23:45 PM »
Do you know of any other ways.
Offline dunk
« Reply #13 on: March 21, 2007, 03:29:11 PM »
there's a few projects here that might be of help:
http://users.frii.com/dlc/robotics/projects/botproj.htm
