Author Topic: Help required in waterproofing of dc motor  (Read 5645 times)
Offline ankit_ipu_niecTopic starter
« on: March 14, 2009, 08:42:17 AM »
hey guys i m in urgent need of your help.
I am making a boat and need to waterproof my dc motor.
if any one know how to waterproof a dc motor please reply to this thread
Thanks in advance  :D
Offline Razor Concepts
  • Helpful? 53
Re: Help required in waterproofing of dc motor
« Reply #1 on: March 14, 2009, 09:26:42 AM »
DC motors can be run underwater (unless you're in salt water). If you are in salt water I would not reccomend submerging the motor itself, I would put a shaft on the motor that connects to the propeller outside of the boats hull.
« Reply #2 on: March 14, 2009, 09:35:50 AM »
thanks Razor for ur immediate response
can you please give me a detailed description of waterproofing in case of salt water is used
Offline Trumpkin
« Reply #3 on: March 14, 2009, 07:55:13 PM »
How big is this boat? You could also try a stuffing box http://en.wikipedia.org/wiki/Stuffing_box
Robots are awesome!
« Reply #4 on: March 14, 2009, 09:14:29 PM »
first of all thanks for your reply.
my robotic boat dimension is 25*15*10 cm(cube).
Offline MaltiK
« Reply #5 on: March 17, 2009, 01:19:04 PM »
you can always wrap everything in plastic wrap or something, but it all depends on the actual liquid it is in, as razor said, as well as the depth you are going. If you are on the surface, pressure is very small or non existent, if very low, pressure is higher, and so water proofing is more difficult and expensive.
Warranty
Offline ArcMan
  • Mmmm... Plasma
« Reply #6 on: March 17, 2009, 01:45:09 PM »
Be careful about wrapping the motor in plastic.  It may not run cool enough.  Most motors depend on open air to remain cool unless they are specifically designed to be sealed.
Offline MaltiK
« Reply #7 on: March 17, 2009, 03:51:16 PM »
But isnt coolness and heat still transferred? Plastic isn't a good enough insulator.
Warranty
Offline ArcMan
  • Mmmm... Plasma
« Reply #8 on: March 17, 2009, 08:37:24 PM »
Heat is still transferred via conduction and radiation, but not convection.  Convection cooling is the primary cooling mechanism for an open-frame motor.  It needs air flow.
« Reply #9 on: March 26, 2009, 12:50:23 AM »
Last post April 10, 2009, 01:05:50 AM
Last post February 03, 2011, 02:49:26 PM
by Fejwin
Last post December 13, 2011, 09:48:41 PM
Last post January 05, 2013, 10:56:24 PM
by Mastermime
