Author Topic: Arduino...Not enough power pins!  (Read 4430 times)
Re: Arduino...Not enough power pins!
« Reply #30 on: March 17, 2009, 01:18:37 PM »
cant you switch the regulator out for a 3.3V? and for the power pins if you dont want to damage the connector on the end you should look online. maybe
www.futurlec.com
www.mouser.com
www.digikey.com
Offline blackheartTopic starter
« Reply #31 on: March 17, 2009, 02:28:35 PM »
I am using a 9V rechargeable battery for the arduino.
I am using a power bus with 4 1.2V rechargeable batteries for the IR rangefinders
I am using the 5V pin on the arduino for vcc on the motor driver
I am using a 9.6V battery pack for the VMOT on the motor driver.
Is everything ok? Did I choose the right battery packs?
I'm out of ideas!
Offline sonictj
  • Helpful? 11
« Reply #32 on: March 20, 2009, 08:41:43 PM »
If your in a time crunch you can use the ir sensors on the 4 1.2V batteries, but I would recommend the 5V regulated power from the arduino if possible.  Your battery will not output a consistent voltage and this could vary your analog signal.
« Reply #33 on: March 20, 2009, 09:16:50 PM »
that pretty much goes for most analogue sensors :) i would use the 5V regulated from the arduino for it.
Last post January 16, 2009, 10:07:32 PM
by Kirk
Last post March 22, 2009, 01:10:33 AM
by SmAsH
Last post March 26, 2009, 01:26:29 PM
by pomprocker
Last post August 22, 2010, 09:34:04 AM
by amando96
