Author Topic: atmega8/168 pinout question  (Read 2917 times)
Offline SmAsHTopic starter
« on: March 15, 2009, 02:00:28 PM »
through reading a few forum posts and googling up some datasheets i have found that there are (correct me if im wrong) 13 digital ports, 5 analogue ports.
digital: 2, 3, 4, 5, 6, 11, 12, 13, 14, 15, 16, 17, 18, 19
analogue: 23, 24, 25, 26, 27, 28
reset: 1 (do you just short it to +5V?)
crystal: 9, 10
gnd: 22, 8
vcc:  7
i think thats all, i am still clueless about what avcc and aref do?
my main question is:
can all digital pins be configured to both inputs and outputs? and can i use all those pins a outputs? now i know about how most sensors give analogue readings and such i need to use an adc port.
Offline superchiku
  • cooll
Re: atmega8/168 pinout question
« Reply #1 on: March 15, 2009, 02:26:40 PM »
avcc and aref provide voltage for the adc...aref is analog reference voltage pin where atod conversion will be done according to the refrence voltage given at that pin...
JAYDEEP ...
IT AND ROBOTICS ENGINEER
  • Helpful? 107
« Reply #2 on: March 15, 2009, 02:42:12 PM »
Yes all I/O pins can be outputs. But NB this is a +5v output with a max current of around 40mA per pin. So you cant just connect a DC motor to the pin. You can connect a couple of servos - so long as their current draw doesn't exceed the 1A available via the voltage regulator.
« Reply #3 on: March 15, 2009, 07:10:10 PM »
yes i know about servos and whatnot with the motor controllers and how you can fry pins. so you're saying even the analogue pins can be outputs?
  • Helpful? 107
« Reply #4 on: March 15, 2009, 10:10:03 PM »
Yes. The ADC converter works with 'channels'. On most packages 'especially a 28 pin' then each pin doubles, or even triples, up - ie it fulfills lots of functions. So the 'analogue pins' can either be used as an analogue channel or as a digit i/o port pin.
« Reply #5 on: March 15, 2009, 11:25:47 PM »
hmm, i will have to look into this. thank you for your help webbot  :D
Offline superchiku
  • cooll
« Reply #6 on: March 16, 2009, 11:20:28 AM »
any pin except the avcc,aref and sum other pins can be configured for i/o
JAYDEEP ...
« Reply #7 on: March 16, 2009, 01:01:07 PM »
there is 14 digital pins and 6 analogue pins.
Last post January 11, 2008, 04:46:16 PM
Last post August 10, 2009, 01:04:07 AM
by Razor Concepts
Last post September 29, 2009, 05:45:46 AM
by Conscripted
Last post September 14, 2010, 04:45:34 PM
by Webbot
