Squirrels have fuzzy tails.
Every time I've seen a button I've always seen it with a 10k resistor.
Quote from: Jdog on March 15, 2009, 04:10:23 PMEvery time I've seen a button I've always seen it with a 10k resistor.Probably because the resistor is when you want a Pull-Up or Pull-Down design - meaning the input pin will constantly be HIGH or LOW until the button is pressed, in which case it becomes the inverse logic value( constant HIGH would become LOW , etc.)
Started by Asellith Electronics
Started by quazz209 Electronics
Started by Digisynth Electronics
Started by popcornhobo Electronics
