Author Topic: does my circuit board work?  (Read 1403 times)
Offline dellagdTopic starter
« on: March 15, 2009, 06:51:00 PM »
is there a simple code I can put into my ATmega8 to see is my $50 board is working?
PLZ HELP THE SCIENCE FAIR IS ON APRIL 1ST!!!!!!!!!
« Last Edit: March 15, 2009, 06:55:40 PM by dellagd »
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
Re: does my circuit board work?
« Reply #1 on: March 16, 2009, 11:21:18 PM »
why can you not just upload the $50 robot code?
« Reply #2 on: March 17, 2009, 06:07:45 AM »
since I am having trouble modifing the servos, i am using the zero servos code, but I can't tell if its working.
« Last Edit: March 17, 2009, 06:24:35 AM by dellagd »
I Won!
Offline paulstreats
« Reply #3 on: March 17, 2009, 11:05:58 AM »
if the led comes on after you program it with the $50 code then it should be working.
« Reply #4 on: March 17, 2009, 02:24:25 PM »
all that happens w/ the zero_servo code is the servo twitches and the led blinks for the samw amount of time.
I Won!
Offline paulstreats
« Reply #5 on: March 17, 2009, 06:23:34 PM »
try loading the full $50 code on and see what happens
Offline Resilient
« Reply #6 on: March 17, 2009, 08:40:24 PM »
So, I assume the zero_servo code, should center the servos? So if the servo centers itself then its working?
If you turn the servo away from the center point while the power is off, does it recenter when you power on?  If so it sounds like it is working.
If its for continuous rotation servos, change the code from a center position to a non center position and see if the servos spin.
« Reply #7 on: March 18, 2009, 01:51:10 PM »
all that happens w/ the zero_servo code is the servo twitches and the led blinks for the same amount of time.
w/ the code the servo will twich about 15 degrees and if I run it again, it will rotate another 15 until about 5 times later it doesn't twitch at all and stays in the same spot. I am not sure if this is what it is suppose to do so I don't know if the circut board is working!!!!
I Won!
Last post April 25, 2007, 10:22:02 PM
by zamboniman60
Last post July 16, 2009, 11:55:49 AM
by Ocelot
Last post July 16, 2009, 09:01:02 AM
Last post June 17, 2010, 06:59:31 AM
by cas64
