Author Topic: 360 servo  (Read 2436 times)
Offline RadikenTopic starter
360 servo
« on: March 16, 2007, 07:13:53 AM »
I need a servo that can rotate 360 degrees, but I need to be able to position the rotation is specific places, so it can't continuously rotate.
Would it be better to:
convert a 180 degree servo I have to 360
or use a continuously rotating servo with specific time delays.
If I go with the first option, how would I convert it?
Or can I buy a 360 degree servo somewhere?
The best way to get to the top is to get off your bottom.
Offline Somchaya
  • You know it's cute!
Re: 360 servo
« Reply #1 on: March 16, 2007, 08:42:11 AM »
I think I've seen some 360 (or a little more) degree rotation servo (but not continuous) at ServoCity.com. I don't know if the price is worth it though.
Using a continuous and basing it off time will probably not be very accurate. Converting the 180 to a 360 would probably be better than using a continuous servo I think.
Somchaya - Back after a year of misc things
http://whisker.scribblewiki.com
Re: 360 servo
« Reply #2 on: March 16, 2007, 05:47:15 PM »
as Somchaya said, its probably a little pricey:
http://www.servocity.com/html/spg785_gearbox.html
you could also perhaps use a stepper motor, or a regular DC motor with an encoder for position feedback
i also remember seeing encoder kits that you can place onto servos that were modified for continuous rotation.
SERVO HELP
Started by ltmhall Misc
Last post October 13, 2006, 10:10:48 AM
by Gopher
Last post April 16, 2007, 05:20:43 PM
by PrinceOfFlame
Last post April 20, 2007, 04:31:43 PM
by 555 timer chip guy
Last post May 20, 2007, 10:49:15 AM
