Author Topic: Programmers and microcontrollers  (Read 1606 times)
Offline mdmedlinTopic starter
« on: March 22, 2009, 07:11:42 AM »
I have access to a BK Precision 864 programmer and a 575A logic tester.  I did not buy these, I just have access to them.  I know that the 864 is obasolete and I may try to finagle our E&I guy to upgrade since all our computers have Vista now, but I digress.  The question that I have is I know that the winevr program is used to program using the programmers on the 50 parts list, but can I use the BK programmer with the code that is supplied, or do I have to write new code? The link to the programmer is here: http://www.bkprecision.com/products/docs/manuals/864_manual.pdf
Thanks again for your support also I tried reading the manual for the tester, will it actually test the IC's with the programms provided, or is that some sort of different test that it runs?
Do or do not, there is no try yes I changed my picture, it is of my daughter.
Re: Programmers and microcontrollers
« Reply #1 on: March 22, 2009, 09:02:44 AM »
Pp 48, 49 tells you which devices you can program.
« Reply #2 on: March 22, 2009, 09:43:53 AM »
Yeah I saw that but I just wanted to make sure that it would be compatible, but for that I guess I would have to know what language the complier uses.
« Reply #3 on: March 22, 2009, 03:52:27 PM »
You either use a binary file or a hexadecimal file representing every byte of the binary file.
Language has nothing to do with it - the code burned into the controller is Machine Code.
Just find out if the programmer you are planning to use wants a binary file or a hex file (most professional programmers use binary files as the default, but can be changed to hex file (beware of the many different hex file formats - Intel hex is one of the most widely used).
« Reply #4 on: March 23, 2009, 03:32:06 AM »
Thanks a lot  ;D
Last post June 20, 2008, 08:31:30 PM
by JesseWelling
Last post July 15, 2008, 01:48:40 PM
by HDL_CinC_Dragon
Last post August 08, 2009, 06:23:34 AM
by Conscripted
Last post March 16, 2010, 12:02:53 AM
by Pratheek
