Author Topic: Simulation of Brain surgery robot in simmechanics(simulink- matlab).  (Read 3550 times)
Offline DharmasasthaTopic starter
hello hai,
         i am simulating four parallel manipulator robot in mechanics, i simulated entire robot. there are two degrees of freedom in my robot, one prismatic(linear in and out motion) and revolute, for rotation(tilt) i am using universal joints. the tilt occur only bez of the parallel manipulator, for eg.can you imagine two parallel manipulator(links)for one link i am feeding force as an input to the motor eg(1cm)next link i am giving negative force(-1cm)so one link will come up and one will go down but two links are fixed. at the end of link i am using universal joint from joint i connected one more body which i am going to tilt.my problem is that i can tilt my entire robot to 0.8cm.
             if i give more than 0.8cm as an input i.e.(force to my actuators-stepper motor)it shows this error "Error originates in Mechanical block dharmasastha_FUSBOT_2links/PLANT/Link 2/Universal. A constraint has been violated. Check constraint solver type and tolerances in the Machine Environment block and Simulink solver and tolerances in Configuration Parameters. Check for kinematic singularities".Even i have changed all the constraint values, but still same error is coming. and i cant open that error dialog box usually we can open the error block in simulink.this s very important for me bez this is my masters(M.S) final year project(dissertation.) with this problem i can't move  next step of my project. please i request you to guide me from this problem.sir/madam please reply for this very important.
Re: Simulation of Brain surgery robot in simmechanics(simulink- matlab).
« Reply #1 on: March 26, 2009, 01:18:32 AM »
Well, first, 0.8cm is a distance not a force . . .
This is why it isn't working. You have a kinematic singularity. That's a fancy way of saying 'impossible by laws of physics'. I do not know what simulator you are using or what it's simulating, but there are two ways to get a singularity:
1) joint velocity approaches infinity
2) sum torque approaches zero (such as a collision, jamming, etc)
I'm not sure what you are studying, but kinematics singularities is a fundamental 101 basic of kinematics :P
Last post April 12, 2007, 04:56:37 PM
by jlipstate
Last post March 27, 2008, 02:52:34 PM
by AndrewM
Last post May 13, 2009, 08:26:34 AM
Last post March 02, 2010, 01:24:44 PM
by Cradboard
