Author Topic: LED in parellel or series?  (Read 778 times)
Offline theanxinTopic starter
« on: March 25, 2009, 05:28:08 AM »
I had connected one resistor 270 ohm with four blue LEDs in parallel but did fried it. After that, i connect one resistor 1k ohm with four blue LEDs but also did fried it slowly. Is it logic if i connect it in parellel or suppose connect in series by every blue LED connect with 1k ohm? Blue LEDs are very expensive so i dont want to buy it again by not fry it. Mind tell me the solution please? I need your guidance
Re: LED in parellel or series?
« Reply #1 on: March 25, 2009, 07:09:43 AM »
Please post a photo or a schematic of how you connected it.
And what voltage did you use?  That is very important if you want a useable answer.
I simply don't have a clue to what you mean here
Blue LED's are cheap if you shop around a bit online.
We don't min telling you the solution, but we can't with the info you provided so far!
Re: LED in parellel or series? *close*
« Reply #2 on: March 26, 2009, 10:48:45 AM »
Finally i get the answered. After measuring using multimeter then i found out that my resistor had short circuit and cause 9v battery fried all the LEDs. :'(.
Last post May 23, 2009, 11:31:48 PM
by Metal Slug 2
Last post June 15, 2007, 06:41:28 AM
by hazzer123
Last post May 07, 2009, 12:53:57 AM
by SmAsH
Last post July 07, 2009, 08:46:14 PM
