Author Topic: Stopping direction of robot, collision avoidance  (Read 1371 times)
Offline cross1933Topic starter
« on: March 25, 2009, 09:10:13 AM »
My robot(MMP-8 mobile robot platform) is controlled with JAVA thru a Lantronix Wireless WBX2100. The WBX2100 is connected to a Servo8 torque board for motor movement. The WBX2100 gets read back from a  Super Logics CP8200 unit. A Dlink DCS-6620G wireless camera provides viewing and relay control. I want to stop this from running into objects or a micro switch when contact is made to halt movement. I need to move in the opposite direction the micro switch that was engaged( if the forward switch is engage only reverse movement is a option). I can have the switched implemented into the JAVA program but the robot continues with its last command if the wireless signal is lost.
Re: Stopping direction of robot, collision avoidance
« Reply #1 on: March 26, 2009, 05:14:11 AM »
How could I use the Sharp IR Distance Sensor(GP2D12) to implement this feature? The output from the sensor is .45V to 2.45V, the pulses from the servo 8 board are from 1 ms to 2 ms with 1.5 ms the center point. Is there a microprocessor card with inputs for both signals?
« Reply #2 on: April 08, 2009, 12:33:05 AM »
If you want the robot to work with a disabled wireless signal, you'll need to use a microcontroller. You can set it up so that the microcontroller takes over the system when the signal goes away . . .
