Author Topic: how to define ports on an atmega8  (Read 3716 times)
Offline SmAsHTopic starter
« on: March 28, 2009, 04:52:51 PM »
hi all my question is in the programming to give a specific pin a name what code would i use? something like this?
//defines
#define   left_sensor    PD0
#define   right_sensor   PD2
#define   right_servo    PD3
#define   left_servo      PD4
or what? sorry if this question has been asked before but i did search and i am a complete novice to programming in all languages :(
thanks in advance,
James.
« Last Edit: March 28, 2009, 05:18:27 PM by SmAsH »
Offline GearMotion
  • Helpful? 24
Re: how to define ports on an atmega8
« Reply #1 on: March 28, 2009, 05:28:09 PM »
//defines
thanks in advance,
James.
It depends a lot on how you manipulate that port. I use defines, and specific code to set/clear the pins:
#define LCD_RESET_H (PORTB |= 0x04)
#define LCD_RESET_L (PORTB &= ~0x04)
then:
     LCD_RESET_L;
to set the line low.
To test the state of a line (on port c):
        if (( PINC & 0x01) == 0x01)
            // Do something
But I'm comfortable with shifting bits, masking, etc in my head. Other programmers prefer writing code in a way that hides these details.
ETA:
For that matter you can do this:
#define   left_sensor    (PIND & 0x01)
and in code:
    if ( left_sensor )
        // do when on
    else
        // do when off
« Last Edit: March 28, 2009, 05:32:42 PM by GearMotion »
« Reply #2 on: March 28, 2009, 05:38:06 PM »
im really sorry but i didnt understand any of that :( i think i might just look up a tutorial on c programming.
thanks for trying to help me anyway :-\
Offline GearMotion
  • Helpful? 24
« Reply #3 on: March 28, 2009, 05:48:13 PM »
Heh - OK. Feel free to bug me about any step that you need to know more about.
Yes, a C tutorial would help you a lot.
Your code:
tells the C compiler that anywhere you have "left_sensor" it should replace it with "PDO".
My code:
replaces "left_sensor" with reading the input register in the mega8 called PIND and masking out all but the lowest but with a "logical and". So in that way you are only looking at the lowest bit in port D.
« Reply #4 on: March 28, 2009, 05:50:41 PM »
okaaaay.... thanks for your help, i found this tutorial that seems to be really set up for beginners: http://www.cprogramming.com/tutorial/c/lesson1.html
Offline GearMotion
  • Helpful? 24
« Reply #5 on: March 28, 2009, 07:24:46 PM »
Well, sorry. I apologize for going too fast. Please feel free to lean on me a bit for help.
Have you looked at the Arduino stuff? The Arduino uses the mega168 which is close to the mega 8. "Arduino" is more than just the hardware - it is also the free development environment. A LOT of people use the Arduino as a starting spot for learning hardware and software.
If you look at the Arduino tutorials, that might help a little bit. The language is basically C and a sample bit of that code studied might help you a bit. If you download the Arduino IDE, you will see that it supports the mega 8.
« Reply #6 on: March 28, 2009, 09:06:12 PM »
yup, ive got me a roboduino sitting in my drawer which is pretty much the same except for power buses?
Offline GearMotion
  • Helpful? 24
« Reply #7 on: March 29, 2009, 09:38:22 AM »
Yes, pretty much. Since there is a lot of Arduino information out there, you can use the tutorials/books to learn the Arduino (close to C) language and easily apply it to your board.
« Reply #8 on: March 29, 2009, 03:04:35 PM »
wait, so does arduino use a different language?
Offline Razor Concepts
  • Helpful? 53
« Reply #9 on: March 29, 2009, 03:12:53 PM »
Arduino is basically C but at a higher level (more basic). The heart of Arduino is C, its just that the thing you actually code into the Arduino software is simpler, and the Arduino software translates that into normal C.
« Reply #10 on: March 29, 2009, 03:15:00 PM »
ahh, so if i learn how to code arduino's will it help me learn c significantly?
Offline GearMotion
  • Helpful? 24
« Reply #11 on: March 29, 2009, 08:11:34 PM »
Yes. Arduino is just C with a lot of helpful library routines.
« Reply #12 on: March 29, 2009, 11:14:47 PM »
ahh good, ill be sure to learn that these holidays!
