Author Topic: resistors for the $50 robot  (Read 1010 times)
Offline mdmedlinTopic starter
« on: March 29, 2009, 07:45:12 AM »
I have a quick question, or actually a few quick questions.  I am making the photoresistors for the 50 robot and I have a question.  Do I use 1/4 w or 1/2 w resistors?  Does it matter which ones I use.  I have noticed that for the LED, I need a 1/4 and for the board, I use a 1/2.  I used the 1/4 because they seemed to be the same size as the ones in the picture.  Also, does it matter what color the resistor is?  I have seen blue and yellow resistors.  Does that make a difference?  Thanks
Do or do not, there is no try yes I changed my picture, it is of my daughter.
Re: resistors for the $50 robot
« Reply #1 on: March 29, 2009, 09:04:08 AM »
1/4 is fine for the photoresistors.
There is basically no difference in functionality between the blue and yellow, the blue resistors are just metal-film resistors and the yellow are carbon resistors.
Offline GearMotion
  • Helpful? 24
« Reply #2 on: March 29, 2009, 09:54:50 AM »
Resistor in series with a photoresistor? (right?) There is very little current flowing through that, so 1/4 (even 1/8) is fine with such low currents.
« Reply #3 on: April 08, 2009, 12:50:04 AM »
remember:
power (watts) = voltage * current
voltage = current * resistance
so:
power = V^2/R
plug in the numbers, and you'll determine the power that goes into that resister is incredibly small.
Last post August 29, 2007, 02:41:06 PM
by snow
Last post January 31, 2008, 11:23:16 AM
Last post October 21, 2008, 12:02:39 AM
Last post July 06, 2010, 08:45:13 PM
by RS232
