Author Topic: Recognizeing a frequency  (Read 3377 times)
Offline 555 timer chip guyTopic starter
« on: March 20, 2007, 05:40:01 PM »
Dos any one have a circuit that can recognize a specific frequency.
Offline sdk32285
Re: Recognizeing a frequency
« Reply #1 on: March 20, 2007, 07:44:42 PM »
do a google search for a notch filter or bandpass filter.
you can use an op amp or a simple RLC circuit.
« Last Edit: March 20, 2007, 07:48:03 PM by sdk32285 »
Offline robot321
« Reply #2 on: March 20, 2007, 07:48:49 PM »
the G8870 decodes DTMF Freqs.
« Reply #3 on: March 21, 2007, 01:37:41 PM »
It needs to be able to recognize square wave forms.
Offline sdk32285
« Reply #4 on: March 21, 2007, 08:15:44 PM »
maybe a DAC before the notch filter. Or use a cap in parallel with the receiver to convert to sinusoidal. I don't know of any offhand but they make tone decoder IC's which also might work
Offline trigger
  • It's an op amp, not a gun part.
« Reply #5 on: March 21, 2007, 08:42:40 PM »
why don't you ADC your signal, and then filter in software? (e.g., use DSP).  Much easier to find a square wave.
There are 10 kinds of people in this world: those who can read binary, and those who can't.
« Reply #6 on: March 22, 2007, 02:06:12 PM »
thanks but I don't know how to do that yet. :(
Offline sdk32285
« Reply #7 on: March 22, 2007, 03:01:30 PM »
You will need to play with the values a lot but here is a basic circuit that should work.
« Reply #8 on: March 24, 2007, 09:13:50 AM »
Thanks for that schematic I was looking at some thing very similar a littel wile ago
do you haze any basic starting values I could use for maybe 100Hz , and also I heard you could use a comparator and a crystal to recognize a frequency.
Offline ed1380
« Reply #9 on: March 24, 2007, 09:18:53 AM »
<-noob
Isn't that what an osciliascope is for?
Offline zamboniman60
« Reply #10 on: March 25, 2007, 06:26:28 PM »
well, if you don't have an extra $160 laying around for an oscillosope, you could use the "inductor in series with an LED brightness test" or the "speaker and function generator guesstimation".
Last post January 25, 2009, 05:44:56 PM
Last post March 01, 2009, 12:04:16 AM
by superchiku
Last post April 04, 2009, 11:08:22 PM
by lemontree
Last post July 01, 2009, 11:26:18 AM
by adison
