Author Topic: 5.25 volts on a 5v I/O analog port?  (Read 919 times)
Offline Its_FridayTopic starter
« on: March 31, 2009, 04:54:38 AM »
I've made a circuit that returns either 0 volts or 5.25 volts, and i need the axon microcontroller to read the voltage using the analog I/O ports. Will 5.25V still be read on a 5V analog I/O port? Or do i need to reduce the voltage?(if so, how? I've already tried voltage regulators but they only give me 5.25 volts)
Offline superchiku
  • cooll
Re: 5.25 volts on a 5v I/O analog port?
« Reply #1 on: March 31, 2009, 06:55:32 AM »
it will be read as 5v anything hiher than te reference voltage isalwaz read as the max voltage... u va drop the voltage by using appropriate series resistance
JAYDEEP ...
IT AND ROBOTICS ENGINEER
« Reply #2 on: March 31, 2009, 09:01:40 PM »
hmmmm I don't know where you found a 5.25V regulator but like 90% of all voltage regulators in the world are 5V. You should get a 5V regulator, as 5.25V will probably damage the ADC of the Axon.
Otherwise do a voltage divider.
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
« Reply #3 on: April 03, 2009, 04:48:18 AM »
I would prefer a resistor zener thing...
Google: "zener regulator wiki"
Cheers!
Last post March 27, 2007, 02:07:22 PM
Last post December 21, 2009, 02:14:56 PM
Last post December 19, 2010, 04:08:36 PM
by madsci1016
Last post November 17, 2010, 10:48:04 AM
by koolniran
