Author Topic: Programming The 50$ Robot HELP!!!  (Read 2246 times)
Offline AbsoluteTopic starter
« on: March 31, 2009, 12:34:40 PM »
Is there any alternative for the AVR STK Serial Port and AVR isp2 programmer for the 50$ ROBOT. I’m planning on making the 50$ robot, but the costs work out too much to ship the programmers to my country.
Could I use ‘USB PIC Programmer K150A’ to program the ATmega8 AVR microcontroller?
AND
Is there any possible way of building your own VR STK Serial Port and AVR isp2 programmer?
« Last Edit: March 31, 2009, 12:36:09 PM by Absolute »
Offline superchiku
  • cooll
Re: Programming The 50$ Robot HELP!!!
« Reply #1 on: March 31, 2009, 12:40:21 PM »
u can build ur own programmer..u need to have a parallel port and a centronics printer cable... ill tell u how if u need it...
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Offline GearMotion
  • Helpful? 24
« Reply #2 on: March 31, 2009, 03:27:45 PM »
I think you should explore using an Arduino, or a Bare Bones Board ( http://www.circuitgizmos.com/products/cgbbb/cgbbb.shtml ) the advantage being that you use a bootloader for the programming, rather than using a programmer. All you need is a USB port (for a regular Arduino) or a serial port for the Bare Bones Board. Or if you build your own, you can get a preprogrammed AVR.
« Reply #3 on: March 31, 2009, 04:05:08 PM »
I have found this schematic. Could i use this?
« Reply #4 on: March 31, 2009, 04:06:44 PM »
Could you show me how if possible.
thanks
Offline superchiku
  • cooll
« Reply #5 on: March 31, 2009, 04:12:57 PM »
u an use the above one and mie too...
mine uses a parallel port and a centronics printer cable
u connect the cable with the mcu in this way..
centronics connector                              mcu
pin 7                                                      reset
pin 8                                                       sck
pin 9                                                       mosi
pin 10                                                      miso
pin 19                                                       ground
mind it this type of programmer is called as a bsd programer and itwont work with avrstudio...or ponyprog...only works with winavr....
JAYDEEP ...
Offline GearMotion
  • Helpful? 24
« Reply #6 on: March 31, 2009, 04:14:06 PM »
thanks
http://www.olimex.com/dev/images/avr-pg2b-sch.gif
Offline GearMotion
  • Helpful? 24
« Reply #7 on: March 31, 2009, 04:15:35 PM »
Offline GearMotion
  • Helpful? 24
« Reply #9 on: April 01, 2009, 08:06:59 AM »
this is the one im attempting now. http://www.instructables.com/id/Ghetto-Programming%3a-Getting-started-with-AVR-micro/?ALLSTEPS
That was -essentially- the first type of programmer I used with AVRs. Since then I've found it worthwhile to get a $30-40 programmer from Digikey.com.
« Reply #10 on: April 03, 2009, 01:01:45 AM »
yea but $30-$40US is about $70-$90 here which is a lot of money to me as im just a student :(
Offline superchiku
  • cooll
« Reply #11 on: April 03, 2009, 07:10:45 AM »
make u own as i told u ..
JAYDEEP ...
« Reply #12 on: April 03, 2009, 07:16:09 AM »
thats what i just did...
Offline GearMotion
  • Helpful? 24
« Reply #14 on: April 03, 2009, 02:37:23 PM »
haha nice gearmotion, i was just about to link him to it ;) you beat me to it! absolute, look down the bottom of the thread and see gearmotions post on the different arrangements of pins you can have.
« Reply #15 on: April 03, 2009, 02:53:52 PM »
Thanks alot guys. i shall give it a shot. 8)
Offline GearMotion
  • Helpful? 24
« Reply #16 on: April 04, 2009, 02:48:27 PM »
Now an update to all of that in the form of a quick blog I put together:
http://circuitgizmos.com/wordpress/?p=272
Last post June 27, 2007, 07:35:09 PM
Last post October 25, 2007, 11:27:02 AM
Last post February 17, 2008, 02:10:07 PM
Last post July 31, 2009, 11:56:47 PM
by apc3161
