Author Topic: Can the Axon control the Dynamixel AX-12+ Robot Actuator  (Read 2165 times)
Offline zephyrusTopic starter
« on: April 02, 2009, 04:50:12 AM »
Hello Sir,
I ordered 10 parts of the servo motor "Dynamixel AX-12+ Robot Actuator"  from Trossen Robotics.
I wonder Sir can the Axon control them all since their requirements are somehow different and how to write the code.
The servo specification is on this page:
http://www.trossenrobotics.com/dynamixel-ax-12-robot-actuator.aspx
Thank you Sir,
Re: Can the Axon control the Dynamixel AX-12+ Robot Actuator
« Reply #1 on: April 02, 2009, 04:57:18 AM »
axon should i think??? but you would have to put up the voltage to your power bus. someone else back me up on this?
« Reply #2 on: April 02, 2009, 11:00:20 AM »
Yes it can, but you can only connect through the I2C connector.
  • Helpful? 107
« Reply #3 on: April 02, 2009, 11:48:06 AM »
Looking at the datasheet it would appear that the actuators could use a UART on the Axon. But rather than having separate Tx and Rx lines they just have one line and they show a diagram of the extra hardware you can add to do this. You would also need to use one digital I/O pin to control this extra hardware that switches the line between Tx and Rx. Then its just a matter of sending out the serial commands in the packet format they describe.
« Reply #4 on: April 05, 2009, 03:08:08 PM »
Hello,
Why using the  I2C connector?
thanks
Offline HDA
« Reply #5 on: February 22, 2010, 07:22:06 AM »
Hi Zephyrus have you find a solution for driving dynamixel parts ? ???
Last post April 06, 2009, 07:04:46 PM
by Webbot
Last post February 22, 2010, 06:01:08 AM
by HDA
Last post June 06, 2012, 09:32:38 AM
by Gertlex
Last post March 01, 2013, 02:09:49 AM
by newInRobotics
