Author Topic: $50 Bot final testing question  (Read 1464 times)
Offline jordiTopic starter
« on: April 03, 2009, 08:05:16 AM »
Finally finished soldering everything and am doing the final testing before installing the microcontroller. I don't have access to a adjustable power supply so all I have to go by is a multimeter.
I've done a connectivity test and everything there seems to be ok but I'm somewhat confused by this line in the instructions - "If you put the multi-meter on the resistance setting, make sure all non-connected pins have at least 5 kohm resistance or you may have power issues."  What exactly is meant by "non-connected pins"? Can someone give me an example of what pins I'm supposed to be checking this way?
Sorry for my ignorance, any advice would be appreciated. Thanks!
Re: $50 Bot final testing question
« Reply #1 on: April 03, 2009, 02:32:40 PM »
by non-connected pins admin meant all the pins like your i/o ports. as in they arent supposed to be joined and if they have a resistance of less than 5K there may be a short.
« Reply #2 on: April 03, 2009, 08:32:56 PM »
Ok,  my meter doesn't show anything when I check non-connected pins using the resistance setting. How could it since they're not connected to each other?   ???
Anyway, I assume that it should be alright then since it passed continuity tests. Next up, plug in the battery pack and look for smoke.  :)
Offline Jdog
« Reply #3 on: April 03, 2009, 08:53:10 PM »
T
They might be connected within the ic but with a very high resistance like 5kohm between them.
« Reply #4 on: April 03, 2009, 09:07:53 PM »
wait did you check the resistance with the chip in the socket?
« Reply #5 on: April 03, 2009, 09:36:29 PM »
No, I haven't installed the chip in the socket yet.
« Reply #6 on: April 03, 2009, 09:48:15 PM »
I wouldn't worry, as long as the continuity check is okay then you should be fine.
« Reply #7 on: April 03, 2009, 09:50:46 PM »
yup as long as none of the pins on the board are touching (except the power bus) you should be fine and when admin said 5k he meant with the chip inserted didn't he? otherwise there is no resistance as you noted ;)
« Reply #8 on: April 03, 2009, 09:56:01 PM »
Sounds good. This project has been a good challenge for my old eyes and not so steady hands. I'll try to post pictures of it if all goes as planned. Thanks!
« Reply #9 on: April 03, 2009, 10:20:11 PM »
how old are you exactly?
Last post January 14, 2008, 02:14:30 AM
by krich
Last post March 05, 2008, 10:37:45 PM
by airman00
Last post May 29, 2009, 11:31:42 AM
by jaabot
Last post October 19, 2009, 04:49:09 AM
by Joker94
