Author Topic: Hubs  (Read 1799 times)
Offline lanamorTopic starter
Hubs
« on: April 03, 2009, 12:54:10 PM »
I'm wondering what you guys do for motor hubs to attach wheels to motors. I'm looking at a motor with a 10mm shaft (linked below). There are hubs specifically designed for these motors but I need wheels with some tread for better traction. Anyone know of a good site to find all sizes of through shaft wheel hubs?
An example would be these wheels
http://www.trossenrobotics.com/store/p/5549-Off-Road-Robot-Tire-4-75-D-x-2-375-W-pair-.aspx
on this motor
http://www.trossenrobotics.com/store/p/4927-16-1-36mm-Planetary-Gearmotor-RS-540-Motor.aspx
Offline ArcMan
  • Mmmm... Plasma
Re: Hubs
« Reply #1 on: April 03, 2009, 01:48:37 PM »
Not much help to you, I'm afraid, but if I need a hub that's not commonly available (like a 10mm shaft hub), I machine it from 6061-T6 aluminum on my lathe.  :)
Re: Hubs
« Reply #2 on: April 04, 2009, 09:59:26 AM »
Yea I don't have the option to make my own. I have access to a wood working shop but that's it.
  • Helpful? 107
Re: Hubs
« Reply #3 on: April 04, 2009, 11:59:07 AM »
Its a pain isn't it. I spent ages trying to find one a while ago. Seem to remember that googling for 'coupling' also came up with some relevant hits.
Offline ArcMan
  • Mmmm... Plasma
Re: Hubs
« Reply #4 on: April 04, 2009, 02:34:52 PM »
Here's a possibility...
You can buy something called a gear blank, which is a gear without the teeth.
Stock Drive has some 10mm bore steel D shaft blanks.  There's no set screw, but you could drill and tap for one.  Then drill holes in the face of the blank to attach it to your wheel.  You can easily file a flat on your shaft to fit the D hole.
http://www.sdp-si.com
Re: Hubs
« Reply #5 on: April 04, 2009, 03:45:25 PM »
Those should work great!! That's a great find; I'll be book marking that site. Thank you very much.
Offline jamort
Re: Hubs
« Reply #6 on: April 04, 2009, 09:29:53 PM »
put a tight washer on it.. or a ruber band stretched tight arough up to it should work
Re: Hubs
« Reply #7 on: April 26, 2009, 07:42:28 PM »
TrossenRobotics.com potentially has some:
http://www.trossenrobotics.com/store/c/3266-BaneBots-Hub-and-Wheel-System.aspx
Banebots Tutorial
Offline 4by4
Re: Hubs
« Reply #8 on: April 27, 2009, 01:58:11 PM »
I've been searching for the same thing for Banebots motors, and found hubs on this site:
http://www.andymark.biz/index.html
Hubs for 0.375 inch and 0.5 inch keyed shafts. Should match the banebots motors, although I haven't actually built a drive with these components yet. Now I'd like an 8-inch or 10-inch pneumatic wheel with a flat hub instead of a bearing-type hub, so I can bolt the AndyMark hub to it.
Offline mdmedlin
Re: Hubs
« Reply #9 on: April 29, 2009, 06:44:22 AM »
for traction for my wheels I used a trapazoidal cog belt turned inside out.  I wrote a wheel tutorial and that has a link in which you can buy the belting by the foot if you need it.  Buy some, cut it to length and glue it to the outside of your wheel for traction.
Do or do not, there is no try yes I changed my picture, it is of my daughter.
Last post April 26, 2008, 04:51:29 PM
Last post October 31, 2009, 06:19:05 PM
by Joker94
Last post May 21, 2012, 07:38:04 AM
by Rent2Own
Last post December 01, 2012, 04:17:15 AM
by sys 49152
