Author Topic: 3.3 ohm resistor with led  (Read 2893 times)
Offline JdogTopic starter
« on: April 03, 2009, 08:51:16 PM »
I'm powering an infrared led with a forward voltage of 1.2 volts and a forward current of 100mA from a AAA battery. The LED calculator said I should use a resistor of 3.3 ohms. Do I really need a resistor if the resistance I'm supposed to use is so low?
Re: 3.3 ohm resistor with led
« Reply #1 on: April 03, 2009, 09:09:51 PM »
you should always use a resistor even if it is 1ohm. it just helps protect the led from burning out ;)
« Reply #2 on: April 03, 2009, 10:01:23 PM »
I guess.
« Reply #3 on: April 03, 2009, 10:16:04 PM »
fine then, go. hook your led up directly to your battery and watch as it burns out faster than normal! >:( ;D lol not really but you can have it hooked up to a battery directly it will just burn out a bit faster than normal.
« Reply #4 on: April 03, 2009, 10:44:27 PM »
The soldering will probably have some resistance, so the resistor might not be needed.
« Reply #5 on: April 03, 2009, 10:47:22 PM »
i thought solder had like .1R resistance?
« Reply #6 on: April 04, 2009, 04:12:13 AM »
If your solderings are that high a resistance that it can protect the IRLED, you better practice... A lot!   ;D
« Reply #7 on: April 04, 2009, 04:18:08 AM »
wouldnt you have to use a tonne of solder to achieve more resistance?
« Reply #8 on: April 04, 2009, 04:22:26 AM »
Your math is wrong. Assuming 6V, I calculated 48 ohms.
What voltage are you powering the LED with? Are you sure its 100mA, because that's a lot for an LED!
« Reply #9 on: April 04, 2009, 04:33:51 AM »
i do agree on the 100ma being a bit much for an led tho.
« Reply #10 on: April 04, 2009, 04:34:35 AM »
If you don't use a resistor, the LED will die, perhaps not instantly, but it won't take long. A fresh AAA has got an internal resistance of between 100 mOhm and 300 mOhm (that's not MOhm in case you wondered) so with 0.3V to spare (with a new cell it would actually be up to 0.45 for a short time), a rough estimate of the current flowing is 1A to 3A!
While the battery wears down, current will go down too and you will soon have no power to the LED. A cell starts at around 1.65V and is considered empty at 0.9V, but your LED won't do a thing below 1.2V, so you will not be able to use up the cell.
If you instead use two cells and a Constant Current circuit, you will have a controlled current for the entire life time of the battery.
Btw. Why do you want to just have an IRLED light?
« Reply #11 on: April 04, 2009, 04:37:10 AM »
As he wrote... An AAA cell.
It leaves the math to: ~0.3V/3.3 Ohm = 91mA
« Reply #12 on: April 04, 2009, 04:39:47 AM »
I have some IRLEDs that are good for ~1A and I have seen them loads beefier.
« Reply #13 on: April 04, 2009, 04:42:17 AM »
triple post much? please try to modify your posts instead of double or triple posting ;) just makes scrolling through topics easier if we only have to go through 10 posts instead of 20-30 :) no offense intended (we've all done it once)
« Reply #14 on: April 04, 2009, 12:10:12 PM »
I didn't say I wasn't going to use one.
I said a AAA battery which is 1.5 volts.
Yes' I'm sure it's 100 mA. Here's the specs if you don't believe me.http://www.radioshack.com/product/index.jsp?productId=2062565&tab=summary
I can't use two cells because I need it to fit inside a highlighter. I'm doing Johnny Chung Lee's multi-touch wii whiteboard project, and I need to make an infrared pen.
« Reply #15 on: April 04, 2009, 12:42:01 PM »
Dang that thing is cool... like a tablet for $40.
Just a thought, maybe open up a 9v battery and get one of the AAAA batteries inside? Those would fit a lot better in a pen.
Last post October 21, 2009, 07:55:37 PM
by waltr
Last post June 01, 2010, 01:45:00 PM
by waltr
Last post September 17, 2010, 10:01:46 AM
by GearMotion
Last post August 04, 2012, 09:16:07 PM
by waltr
