Author Topic: Help with Stamp Box with basic stamp 2sx  (Read 1586 times)
Offline GeoegeTopic starter
« on: April 04, 2009, 01:54:53 AM »
Need help with getting servos to turn or better yet programming tips.
« Last Edit: April 04, 2009, 01:57:11 AM by Geoege »
Re: Help with Stamp Box with basic stamp 2sx
« Reply #1 on: April 04, 2009, 02:13:04 AM »
wait so please explain your question further. please include:
what language you want to program in
what you want it to do
what your experience is
and what microcontroller your using, then we can talk.
Offline superchiku
  • cooll
« Reply #2 on: April 04, 2009, 02:27:05 AM »
duh basic stamp means it should use basic language.. .i think.. .
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Offline Canabots
  • Helpful? 6
« Reply #3 on: April 04, 2009, 06:04:05 AM »
The BASICStamp serries uses a programming language called PBASIC. It is supposed to be very similar to BASIC. I'm sure you can find information about servo control and syntax on the internet. Also, if you already have the PBASIC software, then start it, go to "Help" -> "PBASIC Reference". You should find all the commands you are capable of using with your version of the software.
www.saltech.wordpress.com
Offline galannthegreat
« Reply #4 on: April 06, 2009, 01:38:53 PM »
There is a million and one books written on BASIC Stamps, that would be a good way to learn about BS2 servo control, and pretty much anything, and don't forget a universe of knowledge is on the web about this too.
Kurt
Offline GearMotion
  • Helpful? 24
« Reply #5 on: April 06, 2009, 03:01:58 PM »
The commands to start with would be the PULSEOUT command and a PAUSE command.
Over and over... :-P
Offline Canabots
  • Helpful? 6
« Reply #6 on: April 06, 2009, 03:51:21 PM »
That I'd most certainly have to agree with. Look around a bit (that's what I did).
You may also want to take a glance at the Boe-Bot Code. It does use the BS2 but coding should be very similar, if not identical. (The BOE-Bot's base uses 2 servos for locomotion).
Last post March 28, 2006, 11:46:12 AM
by Afroman
Last post January 05, 2007, 10:17:31 PM
by Handmixer.com
Last post July 17, 2007, 09:22:02 PM
by Robotboy86
Last post January 14, 2010, 07:43:30 PM
by TrickyNekro
