Author Topic: $50 Robot AVR ISPII help  (Read 1268 times)
Offline the jeenyusTopic starter
« on: April 06, 2009, 03:10:00 PM »
Hello. I decided to make the investment and buy the more expensive programmer, and it finds the device and all, but I do not understand a lot of what is going on, so I decided to ask for help!
When I attempted to download the hold servo hex file, I tried to do that in AVR Studio, under the AVR ISPII programer options, on the program tab, and the only options I see are to use 'flash' or 'EEPROM' or something. I dont know what those mean lol. Everything is fine until a message tells me that it only operates under 5kHz or higher. HOw would I adjust that? Please help me, and thank you very much in advance.
Offline GearMotion
  • Helpful? 24
Re: $50 Robot AVR ISPII help
« Reply #1 on: April 06, 2009, 03:18:37 PM »
"flash" is the program space where you would put your code. It is the memory that survives from power-up to power-up (as opposed to RAM which is where variablea are stored, but the contents don't survive power going away). The AVR executes the code that you put into flash.
The EEPROM is similar to the flash as the contents remain from power-up to power-up, but EEPROM is for data, not executable code.
The hex file should be programmed to the flash.
« Reply #2 on: April 06, 2009, 04:02:39 PM »
Thank you very much for explaining that to me. Now, when I attempt to program it, how do I reset the frequency to whatever the program needs?
Offline GearMotion
  • Helpful? 24
« Reply #3 on: April 06, 2009, 04:05:34 PM »
The ISP (programming) frequency? There is a "board" tab in the programmer window, and an ISP freq selection.
« Reply #4 on: April 06, 2009, 04:14:06 PM »
Thank you very much, I sucessfully programmed it.
Offline GearMotion
  • Helpful? 24
« Reply #5 on: April 06, 2009, 04:16:41 PM »
Yay! I'm glad I could help!
Last post February 08, 2007, 01:23:07 PM
by hgordon
Last post February 07, 2009, 03:05:28 AM
by horo333
Last post November 14, 2008, 12:45:55 PM
by Kirk
Last post January 29, 2009, 05:21:27 PM
