Author Topic: Move servo 5 degrees from location  (Read 1566 times)
Offline offyTopic starter
« on: April 08, 2009, 05:25:07 PM »
This is some of my code, I want to make it so Servo "head" moves 5 degrees from the location it is at when I press Q.
  if( val == 'Q' )
I have no idea what to put here
head.write(someting);
Re: Move servo 5 degrees from location
« Reply #1 on: April 08, 2009, 06:00:50 PM »
You have to keep track of what value you told the servo to go last.
headValue = headValue + 5;
head.write(headValue);
An added value of 5 may not be 5 degrees, depends on the servo.
« Reply #2 on: April 08, 2009, 06:17:24 PM »
This doesn't work, I am trying to do it with softwareservo
   if( val == 'E' )
   headValue = headValue - 5;
   SoftwareServo::refresh();
« Reply #3 on: April 08, 2009, 06:27:01 PM »
You should add some other things to make sure headValue is in between 0 and 180. Also the headValue is being updated in all the other parts of the code, right?
« Reply #4 on: April 08, 2009, 06:29:27 PM »
It wont work, I first want to fix this.
« Reply #5 on: April 08, 2009, 07:21:05 PM »
Can you post the whole code?
« Reply #6 on: April 08, 2009, 07:26:59 PM »
#include <Servo.h>
#include <SoftwareServo.h>
Servo right;
Servo left;
SoftwareServo head;
int pos = 0;
int headValue = 0;
char val;
void setup() {
  right.attach(9);
  left.attach(10);
  head.attach(11);
  Serial.begin(9600);
void loop() {
  if( Serial.available() )
    val = Serial.read();
  if( val == 'A' )
    left.write(135);
    right.write(135);
  if( val == 'D' )
    left.write(45);
    right.write(45);
  if( val == 'W' )
    left.write(45);
    right.write(135);
  if( val == 'S' )
    left.write(95);
    right.write(95);
    delay(250);
    left.write(135);
    right.write(45);
  if( val == ' ' )
    left.write(96);
    right.write(96);
  if( val == 'Q' )
   if( val == 'E' )
  delay(1);
« Reply #7 on: April 08, 2009, 07:40:23 PM »
Pressing q should work to increment headValue. So does the code work when you press q?
E will not work since headvalue is at 0 and pressing E will get it down to -5 which is not a valid number for a SoftwareServo.
« Reply #8 on: April 08, 2009, 08:01:48 PM »
Ok, I fixed the E part, but I now have a problem, it doesn't go the same distance the same time on the edges, instead of 1 move, it takes like 10.
#include <Servo.h>
Servo right;
Servo left;
SoftwareServo head;
int pos = 0;
int headValue = 0;
int headValue1 = 180;
char val;
void setup() {
  right.attach(9);
  left.attach(10);
  head.attach(11);
  Serial.begin(9600);
void loop() {
  if( val == 'A' )
    left.write(135);
    right.write(135);
  if( val == 'D' )
    left.write(45);
    right.write(45);
  if( val == 'W' )
    left.write(45);
    right.write(135);
  if( val == 'S' )
    left.write(95);
    right.write(95);
    delay(250);
    left.write(135);
    right.write(45);
  if( val == ' ' )
    left.write(96);
    right.write(96);
  if( val == 'Q' )
   headValue = headValue + 50;
   if( val == 'E' )
   headValue1 = headValue1 - 50;
   head.write(headValue1);
  delay(1);
« Reply #9 on: April 08, 2009, 08:07:49 PM »
Not sure what you were doing in that... here is code that should work:
#include <Servo.h>
Servo right;
Servo left;
SoftwareServo head;
int pos = 0;
int headValue = 0;
char val;
void setup() {
  right.attach(9);
  left.attach(10);
  head.attach(11);
  Serial.begin(9600);
void loop() {
  if( val == 'A' )
    left.write(135);
    right.write(135);
  if( val == 'D' )
    left.write(45);
    right.write(45);
  if( val == 'W' )
    left.write(45);
    right.write(135);
  if( val == 'S' )
    left.write(95);
    right.write(95);
    delay(250);
    left.write(135);
    right.write(45);
  if( val == ' ' )
    left.write(96);
    right.write(96);
  if( val == 'Q' )
if(headValue > 180)
headValue = 180;
   if( val == 'E' )
if(headValue < 0)
headValue = 0;
  delay(1);
Last post August 31, 2008, 09:39:09 PM
by MarkBrown
Last post March 02, 2009, 04:40:42 PM
by offy
Last post June 03, 2009, 03:46:04 PM
by FruitandVeg
Last post October 27, 2011, 08:05:20 AM
