Society of Robots
     | Robot Forum | Robot Tutorials | Robot FAQ |
September 10, 2010, 12:59:44 AM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: SoR Robot Chat every friday night. Join us! (forum integration fix coming when I have time)
http://www.societyofrobots.com/robotforum/chat/
Robot Forum
   Home   Help Search Login Register
Pages: [1]
  Print
Author Topic: help me with ATmega32..  (Read 941 times)
cannonTopic starter
Beginner
Helpful? 0
Offline Offline
View Profile
« on: April 12, 2009, 12:41:38 AM »
I had successfully completed d $50 robot with ATmega8..
when i try to do d same using ATmega32, i cant program it correctly..
I hav been using the same code as be4..
I just changed d pin numbers to that of 32..
shd i change the SoR_utils, etc to make it wrk for 32??
pls help..
Logged
Razor Concepts
Supreme Robot
Helpful? 49
Offline Offline
View Profile WWW
« Reply #1 on: April 12, 2009, 12:44:57 AM »
Change the MCU name in the makefile to atmega32
Logged
cannonTopic starter
Beginner
Helpful? 0
Offline Offline
View Profile
« Reply #2 on: April 12, 2009, 12:53:56 AM »
did tht..
wht i basically wanna knw is whether it wil wrk with the old header files??
Logged
Razor Concepts
Supreme Robot
Helpful? 49
Offline Offline
View Profile WWW
« Reply #3 on: April 12, 2009, 01:54:03 AM »
Try a LED blink program or something. The source files for the mega8 are from AVRlib - may or may not work with the mega32. I've tried with a mega644 and the avrlib source files don't work.
Logged
superchiku
Supreme Robot
Helpful? 5
Offline Offline
cooll
View Profile
« Reply #4 on: April 12, 2009, 02:24:22 AM »
see everything has to be changed...atmega32 has a diff set of pins and also registers inside it...the same program wont work...u have to change the initialization part and many more . .
Logged
JAYDEEP ...
IT AND ROBOTICS ENGINEER
cannonTopic starter
Beginner
Helpful? 0
Offline Offline
View Profile
« Reply #5 on: April 12, 2009, 03:24:39 AM »
i had tried led blink program.. prob is port can be turned on only, it cant be turned off..
and i'm not tht much of a prog genius..
can anyone giv me prog with req initializations for atmega32??
or atleast some place whr i can find instructions for d same??
Logged
SmAsH
Supreme Robot
Helpful? 75
Offline Offline
SoR's Locale Electronics Nut.
View Profile
« Reply #6 on: April 12, 2009, 03:43:17 AM »
are you sure you can turn it on? if you can turn it on you should be able to turn it off with the right code.
Logged
cannonTopic starter
Beginner
Helpful? 0
Offline Offline
View Profile
« Reply #7 on: April 12, 2009, 03:49:17 AM »
for eg, if i giv
PORT_ON(PORTB,0), only tht turns on..
but it doesnt turn off by giving,
PORT_OFF(PORTB,0)
 Huh
Logged
superchiku
Supreme Robot
Helpful? 5
Offline Offline
cooll
View Profile
« Reply #8 on: April 12, 2009, 08:40:42 AM »
i can give u a direct code for atmeaga32...it started with atmega16 but the structure of 16 and 32 are completely same..
Code:
# include<avr/io.h>
int main(void)
 DDRD=0x01;
 TCCR1B|=((1<<CS10)|(1<<CS11));
 while(1)
  if(TCNT1>=3000)
    PORTD^=(1<<2);
TCNT1=0;
 return(1);
this is flashing led with 1 sec gap
Logged
JAYDEEP ...
Admin
Administrator
Supreme Robot
Helpful? 110
Offline Offline
View Profile WWW
« Reply #9 on: May 13, 2009, 09:48:48 PM »
http://www.societyofrobots.com/step_by_step_atmega168_swapout.shtml
Logged
Pages: [1]
  Print
Jump to:
Subject Started by Replies Views Last post
ATMega32 and sensors
Software
bobl 4 1843 Last post July 29, 2007, 08:20:50 AM
by dunk
Finished Schematic of Atmega32 Board
Electronics
Trumpkin 15 4155 Last post September 29, 2008, 11:57:13 AM
by ceruleanplains
how to code Micromouse on ATMega32
Software
sandy 2 2064 Last post February 05, 2009, 08:38:50 AM
by horo333
programming atmega32 using a laptop
Electronics
academicloody 7 822 Last post March 24, 2009, 04:45:06 PM
Powered by MySQL Powered by PHP Powered by SMF | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Advertise on this Forum
