Author Topic: help me with ATmega32..  (Read 2200 times)
Offline cannonTopic starter
« on: April 11, 2009, 11:41:38 PM »
I had successfully completed d $50 robot with ATmega8..
when i try to do d same using ATmega32, i cant program it correctly..
I hav been using the same code as be4..
I just changed d pin numbers to that of 32..
shd i change the SoR_utils, etc to make it wrk for 32??
pls help..
Offline Razor Concepts
  • Helpful? 53
Re: help me with ATmega32..
« Reply #1 on: April 11, 2009, 11:44:57 PM »
Change the MCU name in the makefile to atmega32
« Reply #2 on: April 11, 2009, 11:53:56 PM »
did tht..
wht i basically wanna knw is whether it wil wrk with the old header files??
  • Helpful? 53
« Reply #3 on: April 12, 2009, 12:54:03 AM »
Try a LED blink program or something. The source files for the mega8 are from AVRlib - may or may not work with the mega32. I've tried with a mega644 and the avrlib source files don't work.
Offline superchiku
  • cooll
« Reply #4 on: April 12, 2009, 01:24:22 AM »
see everything has to be changed...atmega32 has a diff set of pins and also registers inside it...the same program wont work...u have to change the initialization part and many more . .
JAYDEEP ...
IT AND ROBOTICS ENGINEER
« Reply #5 on: April 12, 2009, 02:24:39 AM »
i had tried led blink program.. prob is port can be turned on only, it cant be turned off..
and i'm not tht much of a prog genius..
can anyone giv me prog with req initializations for atmega32??
or atleast some place whr i can find instructions for d same??
« Reply #6 on: April 12, 2009, 02:43:17 AM »
are you sure you can turn it on? if you can turn it on you should be able to turn it off with the right code.
« Reply #7 on: April 12, 2009, 02:49:17 AM »
for eg, if i giv
PORT_ON(PORTB,0), only tht turns on..
but it doesnt turn off by giving,
PORT_OFF(PORTB,0)
Offline superchiku
  • cooll
« Reply #8 on: April 12, 2009, 07:40:42 AM »
i can give u a direct code for atmeaga32...it started with atmega16 but the structure of 16 and 32 are completely same..
# include<avr/io.h>
int main(void)
 DDRD=0x01;
 TCCR1B|=((1<<CS10)|(1<<CS11));
 while(1)
  if(TCNT1>=3000)
    PORTD^=(1<<2);
TCNT1=0;
 return(1);
this is flashing led with 1 sec gap
JAYDEEP ...
Last post April 04, 2010, 01:39:28 PM
by 2black0
Last post January 07, 2011, 06:42:33 AM
by TrickyNekro
Last post June 13, 2011, 04:04:35 PM
by Remix
Last post August 14, 2011, 06:52:46 AM
