Author Topic: photodiode  (Read 1347 times)
Offline theanxinTopic starter
photodiode
« on: April 12, 2009, 02:00:45 AM »
After i applied photodiode with infrared LED in line follower, Why it is only can move on the mirror but white paper cant?
Re: photodiode
« Reply #1 on: April 12, 2009, 02:25:43 AM »
wut? please explain further, from what i got out of that your led is not strong enough. but please explain a bit more on your setup and what is going wrong with it so i can help you more.
Re: photodiode
« Reply #2 on: April 12, 2009, 10:26:14 AM »
FOR BLACK LINE FOLLOWER
Actually that circuit i got from pratheek in society of robot website (line follower without microcontroller). Actual is LDR with LED. From there, i got think of trying to use photodiode to see what will happen further. From the basic learning that i know photodiode must receive reflection from the infrared light then only will give respond to it.
After i built up everything completely, I found out that LDR can use in any surface but must have light and dark surface because light surface is for LED to transmit the light so the light will reflect back to the LDR while dark surface will absorb maximum light. While i try to test photodiode on the light and dark surface same as i try on LDR, it does not give any respond to it. This make me crazy ???, then i try to get the mirror (women love to use mirror when doing make up) and try on it. Finally, it give respond to the photodiode.
In conclusion, i think infrared LED need the surface such like mirror to reflect the infrared light to the photodiode while LED (normal LED) need the light surface (like white paper) to reflect the LED light to the LDR. LED oso able to use on the mirror because mirror also is light surface :P but infrared LED cant use on white paper :-\ because of the surface.
Re: photodiode
« Reply #3 on: April 12, 2009, 10:46:48 AM »
[...] (women love to use mirror when doing make up)
Luckily, or they'd look a bit funny afterwards ;D
Nah, you just need to get your circuitry and its sensitivity right for the given purpose.
Please post the schematic of the exact circuit you build and we can advice the changes necessary.
Re: photodiode
« Reply #4 on: April 12, 2009, 11:15:50 AM »
« Last Edit: April 13, 2009, 08:39:53 PM by theanxin »
Re: photodiode
« Reply #5 on: April 12, 2009, 12:19:38 PM »
What you just posted are PCB overlays (with errors and missing links it seems).
Please post the schematics!
Last post July 26, 2008, 10:46:44 PM
by byuri
Last post September 06, 2008, 11:10:00 PM
by zanynik
Last post January 23, 2012, 03:46:49 PM
