Author Topic: Motor/Power/ Drive recomendation?  (Read 4522 times)
Offline minotaurTopic starter
« on: March 25, 2007, 07:22:35 PM »
Gang,
Can any of you get me a recomendation on the following. Thanks!
1) Need to build a small wheeled platform that traverses 95% of  flat indoor floorings. ( I presume this leaves out tracked vehicles.)
2) It needs to carry about 2.5 -3 lbs including its own weight.
3) I will visually be able to drive it remotely.
4) I plan to use a lead acid rechargable batt because I am guessing I will need a 2Ah battery (heavy..)
A) Is 4 wheel drive recomended?
B) DC motor, stepper motor, or servo?
C) Speed is not critical but what torque/ power would you guess is needed?
Thanks to all the experts here to set some initial criteria for my testing!
Offline trigger
  • It's an op amp, not a gun part.
There are 10 kinds of people in this world: those who can read binary, and those who can't.
Offline Somchaya
  • You know it's cute!
Re: Motor/Power/ Drive recomendation?
« Reply #2 on: March 25, 2007, 08:34:17 PM »
A) You don't really need a 4 wheel drive. I'd recommend using a differential drive, since it's a lot easier to construct.
B) All 3 kinds would work actually, although a DC motor might be too fast (unless it's a geared motor or you gear it down) to control remotely properly.
C) Hmm.. I'm not very good with torque calculations.
So, I recently built a differential drive robot with a single castor, that carries around 3 lbs of weight. I used 2 standard servos originally, and the speed for that was ok, although torque was kind of low. However, I used really big wheels which reduces the torque. So, for a robot carrying 2.5 - 3 lbs, those standard servos should work fine, especially if you get decent sized wheels unlike me ;D
If you're intending to drive it remotely, it's probably better to go for a lower speed, unless you're really good with remote control cars :P Personally, I'm terrible at that so I have trouble controlling my robot even though it's not going very fast.
Somchaya - Back after a year of misc things
http://whisker.scribblewiki.com
« Reply #3 on: March 28, 2007, 07:24:28 AM »
Trigger, not sure what you wanted me to see in the link, most of that information is pretty basic, so let me know if I missed something.
Somchaya,
Good info, this is helpful. What standard servos did you use? I agree on the difficulty driving remotely, especially since I have quite a bit of transport delay/ lag. Hitting a wall is bad, hitting a wall fast and far away is even worse...
Offline Somchaya
« Reply #4 on: March 28, 2007, 07:47:26 AM »
I used the Hitec HS-425BB (http://www.servocity.com/html/hs-425bb_super_sport_bb.html). It has a torque of 57 oz/in at 6V and can go at 62.5 rpm.
I ultimately upgraded the servos to higher-torque ones, but if you don't use huge wheels I think it should be sufficient  :)
Offline sotu
  • ïBB - Eye Biped Bot
« Reply #5 on: April 05, 2007, 06:56:44 AM »
A 2 wheeled robot is cool and got nice turnings but not to stable.
How to build a biped bot:
Offline Somchaya
« Reply #6 on: April 05, 2007, 09:00:23 AM »
Well, a 2-wheeled robot with a caster wheel is pretty stable, as long as you don't keep the weight balanced left/right. Well, I suppose if you turn really quickly there's a higher chance of falling, but usually that's not an issue :)
Diff drive robots are a lot easier to construct than their 4-wheel counterparts, esp if you want to use ackerman (i.e. car) steering methods..
Offline sotu
« Reply #7 on: April 05, 2007, 01:47:12 PM »
I got a 7 wheeled robot..:P
Offline Somchaya
« Reply #8 on: April 05, 2007, 09:03:50 PM »
Good for you :) A 2-wheeled diff drive robot is still easier to build for someone who isn't very mechanically-inclined though..
Offline jshalcott
  • The Party Has Arived
« Reply #9 on: April 05, 2007, 11:53:29 PM »
If i was going to use the differental steering, but still have four wheels. Since my dc motor is not geared could i hook it up to a gear and also still a sprocket with a chain to the front wheel. my motor is an 18 volt
DONT DO DRUGS!!!!
Offline sotu
« Reply #10 on: April 06, 2007, 03:09:40 AM »
Yeah, but offcourse not all of the 7 wheels are drift wheels. There are swinging wheels and support wheels to
Offline Somchaya
« Reply #11 on: April 06, 2007, 08:00:05 AM »
Yeah that should be possible. I'm not exactly sure what you mean by "hook it up to a gear and also still a sprocket with a chain to the front wheel" though, but linking the two wheels on each side together with gears or chains is definitely possible.
http://www.lynxmotion.com/Category.aspx?CategoryID=30 has some 4 wheel drive differential robots. You can have a look at how they put it together and maybe that's what you had in mind?
Offline ed1380
« Reply #12 on: April 06, 2007, 10:01:38 AM »
I think he mean using a jackshaft. a gear on one side and a sprocket on the other
Offline sotu
« Reply #13 on: April 06, 2007, 04:44:50 PM »
Im planning on making a 2 wheeled robot (with support wheel)! it seems so easy just adding power to 1 of the wheel and not to the other for turning..!
Offline Somchaya
« Reply #14 on: April 06, 2007, 05:18:21 PM »
Yep, diff drive robots are very easy in that regard.. However, after working with them a little, I realized it's a little troublesome when you want them to turn at a particular turn radius.. since you have to work with relative wheel speeds. A robot with ackerman steering would be easier in that way I think, since you can have separate inputs for robot speed, and robot turn angle..
Still, diff drive robots are much easier to work with in general I think..
Offline sotu
« Reply #15 on: April 07, 2007, 04:32:59 AM »
On the robot i'm making now i have a turning mechanism where a little round toothed wheel is connected to a plastic board with to wheels in each end. When i add power the toothed wheel turn to one side and drift the wheel with it so it turns. But ti cant do very sudden turns.
Offline ed1380
« Reply #16 on: April 07, 2007, 05:25:10 AM »
I believe it's called rack and pinion. standard on most cars now. except on cars they have a hydraulic pump helping you
Offline TravelingPencil
« Reply #17 on: April 26, 2007, 04:27:24 PM »
extreme positive camber makes for a robot frame that can carry alot of weight. pair it with a good gearmotor and it supports and drives heavy loads(asuming u use strong enough materials)
Last post October 28, 2007, 05:32:33 PM
Last post January 20, 2008, 09:40:55 AM
by ed1380
Last post January 30, 2008, 04:15:21 AM
by MicHaeL
Last post April 24, 2010, 07:47:28 AM
by Cristi_Neagu
