Author Topic: community project: electronics aspects  (Read 3997 times)
Offline Asellith
  • Helpful? 9
Re: community project: electronics aspects
« Reply #30 on: June 02, 2009, 08:57:20 AM »
@Admin Dunks original write up called for all uart pins to be taken out to headers so that on board debugging could be used.
I go in for surgery this thursday after that I hope to get my life back in order and organize this stuff as well as the sourceforge site. Then I want to finalize a version of the standard. Then get the in progress modules organized and listed on sourceforge.
Right now we need coders bad to start getting the libraries and initial modules programmed and tested. I have seen a lot of pcb designs but no code or working prototypes.
Jonathan Bowen
CorSec Engineering
www.corseceng.com
Offline dellagd
« Reply #31 on: June 02, 2009, 01:56:58 PM »
idea revised
changing addresses is a bit ahead. I thought of having a set of relays so that if a button is pressed it will tell a certain module to do a certain thing.
If I helped, +1 helpful pls
I Won!
3rd place! I'm taking $100
Offline SmAsHTopic starter
« Reply #32 on: June 02, 2009, 02:22:29 PM »
why? do what?
why not transistors?
Offline dellagd
« Reply #33 on: June 02, 2009, 05:29:47 PM »
or transistors, relays just came to mind :P
like you could put in the code that is pin 5 comes high send the bit "3" to mod 12636372. the bit "3" might make a servo at the module turn to the right
I Won!
Last post June 05, 2009, 01:39:05 AM
by SmAsH
Last post January 21, 2009, 04:13:12 AM
SOR community project?
Started by SmAsH « 1 2 3 4 5 » Misc
Last post June 05, 2009, 03:25:28 PM
by SmAsH
Last post May 17, 2009, 06:57:54 PM
by Ro-Bot-X
