Author Topic: Problem With ATmega16 Reset  (Read 5539 times)
Offline hendrachubbyTopic starter
« on: April 25, 2009, 12:13:31 PM »
HI All,
I got problem using avr isp mk2 programmer in my board, i usually use avr isp 910 to program my board and it works fine but the programmer is really slow so i bought mk2. When i use mk2 as the programmer it just error ( avr isp mk2 can't enter programming mode ). I also already upgrade the mk2 using avr studio 4.14, so i think maybe there is something on the board that can't support mk2 programmer. I attach my atmega16 board so maybe somebody can help me.... thx
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
Re: Problem With ATmega16 Reset
« Reply #1 on: April 26, 2009, 12:33:56 PM »
replace that 10K resistor with a 4K7 one... at the reset circuit...
Also place a 100nF from the reset to ground...
That's the two first step you gotta consider before thinking of anything else...
Cheers!
« Reply #2 on: April 28, 2009, 02:09:54 PM »
I already done that, but still it can't enter programming mode, can you help me with recomended reset circuit ?
Offline GearMotion
  • Helpful? 24
« Reply #3 on: April 28, 2009, 02:15:44 PM »
Get rid of the LED.
  • Helpful? 111
« Reply #4 on: April 28, 2009, 03:31:58 PM »
That schematic shows a 10 pin ISP header whereas the AVRISP MKII only has 6 pin socket - how are you converting from one format to the other?
« Reply #5 on: April 28, 2009, 11:11:16 PM »
I convert it by jumpering the wire from 6 to 10 wire, i think it's ok, because i when try program the uC with the reset switch pressed the programmer can enter programming mode and download the program. The avr studio error message says that i use to strong pullup resistor..
