Author Topic: $50 robot programing  (Read 10136 times)
Offline ed1380Topic starter
« on: March 27, 2007, 04:30:31 PM »
Is the source code for the $50 debugged and working?
I have a report due in a few weeks, about any topic I choose and think this would be a great way to take my first step into actually building a robot, and getting to show off at school 8)
Will a 9.6v ~2000ma/h battery be good? Got a couple of those laying around not being used.
Re: $50 robot programing
« Reply #1 on: March 28, 2007, 04:41:01 AM »
Yeap it works. But I recommend getting the ~$30 programmer cause I havent had time to figure out what went wrong with the cheaper one . . . the issues are all explained in the tutorial.
Yes and no. The servos are rated for a maximum of 6V (meaning they will fry if you go much higher). You could of course use a switching regulator to step the 9.6V down to 6V. The microcontroller circuitry will seperately use the 5V regulator so no need to worry about that.
http://www.dimensionengineering.com/DE-SWADJ.htm
« Reply #2 on: March 28, 2007, 05:24:44 AM »
Will I be able to use that programmer in the future when I go more advanced? Will it work with the more advance mcu's?
Can I get another 5v voltage regulator and use that for the servo's, cause I'm not too excited spending $15 on a voltage regulator?
If anything I'll use a 6v battery pack.
« Reply #3 on: March 28, 2007, 05:48:48 AM »
Search digikey for ATAVRISP2 and check the datasheet for what it supports. The more expensive one is better and supports more AVR's. Its the one I normally use, and I think most people use.
Nope. A regular regulator is extremely inefficient and will fry with all the wasted heat.
Offline dunk
« Reply #4 on: March 28, 2007, 09:12:05 AM »
unless you research "switching regulators" which are typically 90% efficient or better but at the expense of added complexity.
the LM2596 for example. http://www.national.com/pf/LM/LM2596.html
« Last Edit: March 28, 2007, 05:42:21 PM by dunk »
« Reply #5 on: March 28, 2007, 03:11:22 PM »
I'm on a really tight budget. I scavanged some heatsinks off an old motherboard. will it work then?
What would you guys recomend for me to do since I'm on a tight budget? suck it up and get it, since I'm going to use it in the future, or use a 6.0v battery pack?
Offline dunk
« Reply #6 on: March 28, 2007, 06:04:03 PM »
so you could use a regular linear regulator from a 9v battery for your servos but the "spare" 4 volts will be converted into heat.
bolting a heatsink on there will help but it really depends how long your servos will be running for.
when i first learned this my regulators were ok while the servos were stationary but they would over heat after less than a minute of movement.
trust us here, linear regulators aren't much good for big voltage drops or anything that draws more than a few hundred milli Amps.
switching regulators on the other hand have little controllers in them that switch the power on and off at high frequency, then smooth out the output with an inductor and capacitor to get the required voltage.
no nasty heat build up and very little wasted power.
using a LM2575, an inductor, a diode and 2 capacitors you can build a 1 Amp switching regulator for under $5.
http://www.national.com/pf/LM/LM2575.html
pick a capacitors, diode and inductor that will be able to withstand more than 1A. (i think from memory the datasheet tells you the minimum specs for these components.)
once you have one of these built you will be able to convert the power from most batteries to 5 Volts.
« Reply #7 on: March 28, 2007, 07:21:41 PM »
Thats awesome. Thanks.
If I were to set the photovore off in the class room what would it do? The room's brightly lit. If I turn off the lights will it follow the beam of a flashlight on the ground in front of it?
« Reply #8 on: March 30, 2007, 05:11:21 AM »
How hard would it be to add or change the source code to a robot with infared object avaoidance? or maybe both and a switch to choose which one would have priority.
« Reply #9 on: March 30, 2007, 11:11:26 PM »
bump? Anyone?
I've tried avrlib, and don't know how to find source codes. All it gives me is a link to a site.
I don't know what to order if I don't know if it''ll work or not.
« Reply #10 on: April 01, 2007, 07:08:21 AM »
Am I seriously going to have to wait until the night before the profect is due to get an answer?  :'(
Offline dunk
« Reply #11 on: April 01, 2007, 11:45:24 AM »
How hard would it be to add or change the source code to a robot with infrared object avoidance?
that depends on whether you understand the source code.
if you can follow the C program then modifying it to use IR rangefinders should just take a little trial and error.
avrlib is source code. download it and unpack it. there you will find lots of shiny source code.
i don't think it will help you much though. avrlib is mainly code for interfacing with some of the more complicated AVR hardware and peripherals.
if all you want to do is change sensor type you should be able to just modify Admins code a bit.
deal with it. people only post here because they enjoy doing so.
if you are not getting a reply, try providing more information or clarifying what you are asking.
maybe you are being too vague. or maybe no one knows the answer.
for example:
don't know. i have never built one.
probably.
(Admin can probably answer these last 2 when he gets back from his trip. 2 more weeks i think.)
« Reply #12 on: April 01, 2007, 03:37:30 PM »
(the admin was invoked :P)
it will run into chair legs, the menace of all hobby robots! (serious, chair legs are hard to avoid with optical sensors - even for experts)
yes
for example:
the issue is that vague questions get vague answers, specific questions get specific answers :P
~15 minutes of google searching can usually help you ask more specific questions  8)
« Reply #13 on: April 01, 2007, 04:46:15 PM »
Thanks.
As long as it'll follow the beam of light it'll be safe from the chair legs.  :)
« Last Edit: April 01, 2007, 04:47:44 PM by ed1380 »
« Reply #14 on: April 08, 2007, 10:37:35 AM »
I was looking around on the web at the arduino, and for $30 it comes with everything the $50 robot's circuity has, and I wouldn't have needed to buy a $15 cable. >:(
Since both are atmega8's wouldn't they program and work the same?
Wouldn't it be better to spend a little more now on teh $50 robot, and have a good platform for later?
Offline dunk
« Reply #15 on: April 08, 2007, 04:51:09 PM »
yup that should work (although i haven't ever looked at the arduino or it's datasheet) but now you have the cable you will be able to program as many atmega8 chips costing just a few $ each.
that's if you intend to build more robots.
and you'll need lots more robots if you are going to take over the world before i do...
« Reply #16 on: April 08, 2007, 05:02:34 PM »
Thanks. but having something prebuild would be better quality then what I could solder up
Me and my friends are already planning on taking over the world and we won't need robots.  8)
Offline NOOBinDistress
« Reply #17 on: April 13, 2007, 06:53:55 PM »
nonesense I ll take over the world before you all HAAAA HAAA HAHAHAHHAHAHAHHAHAHAHAHAHAHHA!!!!!!!!!!!!!!!!!!!!!!!! >:( >:( >:(
« Reply #18 on: April 16, 2007, 10:45:52 AM »
I think the chip is fried. anyway i could send it to someone who already has done the $50 robot, so they could give it a shot? admin? noobindistress?
« Reply #19 on: April 20, 2007, 02:25:01 PM »
I got this
What is L1 in the lm2575 usage diagram? By the datasheet it looks like you wire it up like the lm2575
« Last Edit: April 20, 2007, 03:04:04 PM by ed1380 »
« Reply #20 on: April 20, 2007, 02:28:55 PM »
I also got  this
Is it a good one? IT say max 2.4a. at what voltage is that?
datasheetarchive, and google doesn' help
Offline dunk
« Reply #21 on: April 21, 2007, 04:37:46 AM »
L1 is an inductor.
the datasheet should tell you what value will need.
I also got  this
so the datasheet is linked off the Alegro motorcontroller page you linked to. (top right: "Datasheets:...")
not that you need it to answer your question.
"36 V output rating" is one of the first lines on the page you linked to....
as for being a good one, the biggest problem i see for you is soldering down the QFN package.
you are going to need to be able to make your own PCBs if you are going to use it.
« Reply #22 on: April 21, 2007, 06:39:21 AM »
I'm not blind I know it's rated for 36v and 2.4a. the problem is that   v*a=w
so 2.4a at 5v is diferent from 2.4a at 36v.
cars are the inverted. they say it makes 300hp, but thats at the redline, so they also say how much hp it makes at Xrpm
might be bad example, but best I could come up with (just woke up)
Offline dunk
« Reply #23 on: April 21, 2007, 07:38:30 AM »
actually, now i look at this again, i meant the datasheet's linked off this page:
http://www.allegromicro.com/en/Products/Part_Numbers/3995/index.asp
here in fact:
http://www.allegromicro.com/en/Products/Part_Numbers/3995/3995.pdf
so the A3995 will run at 2.4a at 36v.
i understand your confusion. it would make logical sense for an H-bridge to have a power rating (in Watts) rather than a voltage and amperage rating.
you would think if you ran it at a lower voltage you would be able to increase the current, right?
i don't know why they don't work like this but any H-bridges i have looked at the datasheets for are all labled in the same way. (ie. a max voltage and a max amperage separately.)
i presume the A3995 can run at max voltage and amperage indefinitely without overheating as long as you have the heatsink soldered on to a biggish piece of copper on the PCB.
« Reply #24 on: April 21, 2007, 09:04:49 AM »
so the reason they must list the voltage rating seperate from the power rating is that electrons tend to jump further distances at higher voltages - causing internal shorts without exceeding the maximum power rating
« Reply #25 on: April 21, 2007, 11:45:57 AM »
thanks.
so that little thing will run 80 watts(under 36v of course)   :o
so 16amps at 5v would work.
« Reply #26 on: April 21, 2007, 01:30:55 PM »
Could you take one of these, and use 4 channels for one output and 4 for another, and hook that up to the mcu and use that instead of a motor driver?
should be alot easier than hooking up the strobe and data and clock to a regular driver.
set high, low for one way.   low, high for reverse, and high, high/low, low for brakes. couldn't you also do PWM?
you should even be able to stack them, or use all 8 channels for one output and another chip with 8 for the other.
Now that I have looked more I should have gotten this one. http://www.allegromicro.com/en/Products/Part_Numbers/2559/index.asp
much more powerful
« Last Edit: April 21, 2007, 01:34:45 PM by ed1380 »
Offline dunk
« Reply #27 on: April 21, 2007, 02:26:42 PM »
so that little thing will run 80 watts(under 36v of course)   Shocked
no. it's still only rated for 2.4A no matter what voltage.
« Reply #28 on: April 21, 2007, 03:56:54 PM »
cmon dunk. ain't you gonna take a stab at the second question?  ;D
Offline dunk
« Reply #29 on: April 21, 2007, 05:51:39 PM »
nope.
you'd more or less answered it yourself.
you are talking about building an h-bridge from those.
there are simple h-bridge motor controllers out there if you want.
try searching for the L293D.
Last post April 28, 2009, 05:20:52 AM
by Miles
Last post September 14, 2008, 10:56:05 AM
by brijesh
Last post December 13, 2009, 10:58:06 PM
by SmAsH
Last post January 31, 2010, 08:14:22 AM
by waltr
