Author Topic: Adaptive Mapping and Navigation with iRobot Create  (Read 1199 times)
Offline armsteadj1Topic starter
« on: May 07, 2009, 08:23:32 AM »
I am currently trying to finish up my independent study of robots using IR for wall detection.. I have been trying to us the instructions from http://www.instructables.com/id/Adaptive-Mapping-and-Navigation-with-iRobot-Create/ but have run into a couple problems..
I have loaded the code but (with the servo only) It sits there and spins.. it will spin the servo a small amount, maybe 90 degrees, then stop and then rotate the robot forever.. I am guessing it is for some reaons not talking correctly to the servo?
Then when I plug in the IR the application wont even load. I hit the reset button and the power button blinks.. unplug the IR and it loads the app and does the above..
Do you have any suggestions to what I am doing wrong? I am in a sort of time crunch but I really have no idea what is wrong =(.. any help is greatly appreciated.
Thank you!
Re: Adaptive Mapping and Navigation with iRobot Create
« Reply #1 on: May 30, 2009, 11:39:44 AM »
Ever get it to work?
Sounds like:
- wiring possibly wrong
- you are using the Stampy code and not wavefront code
- battery possibly low
Last post December 02, 2007, 09:30:49 AM
by bootstrap
Last post January 09, 2008, 12:16:51 PM
by Ro-Bot-X
Last post April 03, 2008, 08:42:04 AM
by learner
Last post August 05, 2011, 10:52:21 AM
by iamaldrin
