Author Topic: choosing batteries  (Read 3141 times)
Offline jshalcottTopic starter
  • The Party Has Arived
choosing batteries
« on: March 30, 2007, 10:03:27 AM »
my robot is more larger than normal robots so i'm going to use a couple of 18v motors. can anyone recomend me a type of battery and where to get this battery.
DONT DO DRUGS!!!!
Re: choosing batteries
« Reply #1 on: March 30, 2007, 04:12:58 PM »
Ok, screw everything I just said above. I got 4 regular 9 volt NiCad rechargebles. But they are seperated, how do I put two of the batteries together
DONT DO DRUGS!!!!
Offline Somchaya
  • You know it's cute!
« Reply #2 on: March 30, 2007, 04:15:06 PM »
Put them together? Just wire them in series?  :)
« Reply #3 on: March 30, 2007, 04:32:55 PM »
so wire the negative to the positve and the same with the other
DONT DO DRUGS!!!!
Offline ed1380
« Reply #4 on: March 30, 2007, 05:19:13 PM »
positive to negative and negative to positive and etc. will add the voltages together. positive to positive and negative and negative will add teh amp/hour rating
« Reply #5 on: March 31, 2007, 12:03:38 AM »
so which one would be better
DONT DO DRUGS!!!!
Offline Somchaya
« Reply #6 on: March 31, 2007, 12:24:02 AM »
If you want to connect 2 9V batteries together to get 18V then you'll want to do them in series (positive to negative connection).
If you connect them in parallel (positive to positive), the overall voltage will remain at 9V but you'll have more battery life.
So from what you're describing, I think you want the series connection :)
