Author Topic: $50 robot Questions  (Read 1725 times)
Offline Jaryd107Topic starter
  • Building my first $50 robot
$50 robot Questions
« on: May 09, 2009, 01:40:16 PM »
I have two questions about my $50 robot. ??? ???
1.I am sodering my board and the soder from one pin touches the soder from another pin. Is this a problem, what should I do.
2.Can i use a 9volt battery or is that too much voltage. I think it would be easier because i have a battery connector thing for the 9v.
Thankyou
Offline Webbot
  • Helpful? 107
Re: $50 robot Questions
« Reply #1 on: May 09, 2009, 04:46:08 PM »
Thankyou
1. Major problem! Try to clean your solder tip and then run it between the two pins to create a gap. Otherwise google for solder wick
2. 9v will be ok so long as it goes via the voltage regulator before hitting the chip
« Reply #2 on: May 09, 2009, 04:48:51 PM »
Kk... im gonna try to fix the solder problem. Oh... and yeah, its going through a regulator.
« Reply #3 on: May 09, 2009, 04:49:33 PM »
to the second question, if you are only using one pack for servos and mcu then you cannot use a 9V
as this will fry the servos...
if you are using the two pack method it will be fine.
Offline Razor Concepts
  • Helpful? 53
« Reply #4 on: May 09, 2009, 04:51:28 PM »
Smash... please read everything twice before posting. He just said it's going through a regulator  ;)
You could use the 9v pack, however the servos draw a lot of current so you will be eating through 9v batteries like crazy.
« Reply #5 on: May 11, 2009, 05:06:17 AM »
Ok... would you recomend just using 4 AA(1.5v) batteries instead?
« Reply #6 on: May 11, 2009, 02:40:49 PM »
i did! i thought he only meant he was using the regulator for the mcu as using it for the servos seems very illogical!
yes, that would work, but are you sure you don't want to consider a rechargeable pack?
if you are serious about going into robotics you should get or make one! because buying all those batteries is a B#$CH.
you can run the board off one pack, but it may have the be a 7V2 pack... as some regulators need more than one volt above the regulated voltage to run.. so, in some cases it is better to use two packs... your choice...
Offline Webbot
  • Helpful? 107
« Reply #7 on: May 11, 2009, 05:36:37 PM »
IMHO You're best with 2 packs.
1 pack for the servos (ie unregulated) which could be say 4xAA rechargeables @ 1.2V each. So say 4.8v. If you go much beyond 5v then check the datasheet for your servo so you dont blow it.
1 pack to go via the regulator to feed the controller circuit. I tend to use a rechargeabl 9v battery. They cant supply much current but your processor doesn't need much.
Last post May 17, 2008, 06:28:34 PM
Last post October 26, 2008, 05:51:16 PM
by izaktj
Last post September 17, 2011, 09:48:29 AM
by Conscripted
Last post October 11, 2011, 01:31:44 PM
by newInRobotics
