Author Topic: parts list  (Read 2970 times)
Offline jshalcottTopic starter
  • The Party Has Arived
parts list
« on: April 01, 2007, 03:00:18 AM »
ok, pleas correct me if i'm wrong. Now for a simple 2 wheeled robot r/c controlled i need (electronic part)
is:
radio transmitter
radio reciever
crystal thingy
ESC
Now for the ESC do i need one for each motor. And do i need 2 recievers or just a atleast a 2 channel one
DONT DO DRUGS!!!!
Offline dunk
Re: parts list
« Reply #1 on: April 01, 2007, 05:16:10 AM »
so usually you would get the radio transmitter, radio receiver and crystal thingy all in the same box from your local radio controll model shop. (you will probably get servos too.)
they stare at 2 channels but if you might want more features later on you might want to get a radio with more.
what is an ESC?
i can only guess it's a motor controller in which case you probably need one for each motor.
some moror controllers have 2 channels though in which case you would only need one. read the datasheet for your motor controller.
an alternative to separate motors and motor controllers is to modify your servos for continuous rotation and use them as your motor and controller combined. they will only be powerful enough for small bots but it would be a good place to start.
search for "continuous rotation servo"
Re: parts list
« Reply #2 on: April 01, 2007, 10:26:24 PM »
thanks dunk I'll do that, and ESC stands for electronic speed controller so your right
DONT DO DRUGS!!!!
Re: parts list
« Reply #3 on: April 07, 2007, 02:39:05 AM »
actually the reciever and 'ESC' are included together. you plug your modified servos directly into the reciever. or if you use simple DC motors, you could also plug the motor controller into the reciever (depending on the motor controller input capabilities).
and you need a battery (up to 6V, unless you use a Y-harness for higher voltages) for the reciever, and i think 7.2V for the transmitter (usually comes with the transmitter).
Re: parts list
« Reply #4 on: April 07, 2007, 11:53:39 PM »
so if you use in esc with that capability you don't need servos, and just plug that into the reciever
DONT DO DRUGS!!!!
Offline ed1380
Re: parts list
« Reply #5 on: April 08, 2007, 10:30:53 AM »
unless you use mechanical servo controlled motor controllers, but then I geuss they'll be call msc :D
Last post January 14, 2010, 07:09:01 PM
by z.s.tar.gz
Last post August 31, 2010, 09:45:12 PM
by Metal Slug 2
Last post June 14, 2011, 07:57:57 PM
Last post July 27, 2011, 08:05:28 AM
by Aberg098
