Author Topic: Resistors?  (Read 1089 times)
Offline xCycloneTopic starter
  • I am a noob at robot =P
Resistors?
« on: May 17, 2009, 07:56:06 AM »
I am building the 50 dollar robot and I bought some resistors from Radio Shack. I needed 1.62 Kohm and a 340 ohm, but they only had 1.5 Kohm and 330 ohm. Would that make much of a difference ???
ROBOTS WILL ONE DAY PWN THE WORLD... maybe.
Re: Resistors?
« Reply #1 on: May 17, 2009, 08:03:27 AM »
I found out more about the 330 via SoR fourm but... I still need help about the 1.62Kohm vs. 1.5Kohm
Offline LunchBox!
Re: Resistors?
« Reply #2 on: May 17, 2009, 09:35:57 AM »
depending on the tolerance band of the 1.62 the 1.5 should be fine.
its most likely a + or - 10% (silver band)
1.62 x 10% = 0.162
1.62 - 0.162 = 1.458
measure ur 1.5's and pick the one with the highest value.
« Last Edit: May 17, 2009, 09:49:02 AM by LunchBox! »
Re: Resistors?
« Reply #3 on: May 30, 2009, 09:31:57 AM »
You'll be fine.
Re: Resistors?
« Reply #4 on: May 31, 2009, 07:04:15 AM »
Ok good thank you both!
Last post July 06, 2010, 08:45:13 PM
by RS232
Last post August 07, 2011, 10:46:24 PM
by z.s.tar.gz
Last post January 27, 2012, 07:30:25 PM
by Gertlex
Last post May 09, 2012, 02:06:29 PM
by jkerns
