Author Topic: sonar algorithm  (Read 4113 times)
Offline vbnandu86Topic starter
sonar algorithm
« on: April 01, 2007, 08:29:00 AM »
i m planning to buid a robot that uses sonar,initially i have planned for it to be stationary and detect objects in its(sonars) range.
My problem is to find an algorithm that can distinguish objects on a plane perpendicular to the (sonars) cone's apex.meaning if there are 2 objects on the same plane it has to identify obj.1 is at co-ordinate say 0,20 and obj. 2 is at 10,20
Please help!
Offline hgordon
  • Helpful? 7
Re: sonar algorithm
« Reply #1 on: April 01, 2007, 08:42:53 AM »
It would be helpful for you to describe the problem in polar coordinates rather than cartesian coordinates.
Take a look at the specs on the sonar unit - what is the beam width (in degrees) ?  Also, does the receiver only return a signal corresponding to the distance to the closest object, or does it process multiple bounced signal returns ?
If you have the possibility of steering the sonar beam, you can build a model which helps differentiate between objects.  Take a look at the tutorial on sonar on this website -
    http://www.societyofrobots.com/sensors_sonar.shtml
Surveyor Corporation
  www.surveyor.com
Last post June 09, 2007, 07:58:58 PM
by rgcustodio
Last post September 26, 2007, 10:49:14 AM
by Ro-Bot-X
Last post December 05, 2007, 07:24:30 PM
Last post November 20, 2008, 03:13:48 PM
by SciTech02
